FS Emile Bertin - Big Gun
Discussion in 'Warship Builds' started by Cannonman, Jan 27, 2015.
  1. Cannonman
    Hermitage, Tn
    Here it is in place. The servo just drops over the stop collar, and the deck holds it down. Not yet installed at the time of this pic are two pieces of 1/8 ply that run the length of the servo on either side, and are glued to the bottom of the subdeck to keep the servo from rotating. Maintenance couldn't be easier, simply remove the deck and pick up the servo, no tools, rubber bands, screws, or other mounting devices whatsoever.
    SteveT44 likes this.
  2. Cannonman
    Hermitage, Tn
    Since it is direct drive, and only a 90 degree travel servo as supplied, I will probably need to modify it for increased travel. I can set my radio to overtravel it a bit, but I don't think it the radio has enough overtravel capability to get me what I need. If all else fails, and I mess up the servo during modding, servo city sells them pre modded to travel 180 degrees.
  3. Cannonman
    Hermitage, Tn
    Out of morbid curiosity, I tried my hand at making the seaplane for the superstructure. It went pretty well, I think. For the fuselage I started with a block of wood and cut off anything that wasn't a seaplane fuselage.
  4. Cannonman
    Hermitage, Tn
    Then I cut out the rest from some sheet plastic I had laying around.
  5. Cannonman
    Hermitage, Tn
    I also did some preliminary work on some superstructure. I still need to figure out some struts to attach the pontoons to the seaplane fuselage.
  6. irnuke
    Toothpicks?
    I like how your building the plane.
  8. Cannonman
    Hermitage, Tn
    Possibly... I haven't really put much thought into it.. I had thought about thin piano wire....
    Thanks Curt... I only wish it looked half as good as your boats, your builds and the detail you put into them humble me!!!
    CURT likes this.
  9. Cannonman
    Hermitage, Tn
    My last issue to deal with before fiberglassing the bottom is this funky area between the outboard shaft and the edge of the penetrable area.
  10. Cannonman
    Hermitage, Tn
    I "built" a little dam out of foil tape, then filled it with west systems.
  11. Cannonman
    Hermitage, Tn
    Finished repair after it cured and received a little sanding and sculpting.
  12. Tugboat
    The plane looks okay, missing a few rivets on the engine cowling... (just kidding!) That looks freaking cool, you're going to make me want to try it :)
    I like your rudder servo setup, too. Where'd you get the brass thingie that goes on the servo splines that connects it to the rudder shaft?
  13. Cannonman
    Hermitage, Tn
    Drat!!!! I'll have to look into the location of those rivets!!! ;)
    Thanks!!
    The brass thingie was scratch made. it's pretty basic turning except for the hex, which was rotary broached (on the lathe).
  14. Cannonman
    Hermitage, Tn
    Getting ready to glass the bottom. First, I covered areas I didn't want globs of epoxy on.....
  15. Cannonman
    Hermitage, Tn
    I pre cut a piece of cloth, I have no clue why I left so much extra :bang:
  16. Cannonman
    Hermitage, Tn
    I'll never find my calling as a photographer of in-process epoxy/ fiberglass application..... I always get frantic and don't get a picture until the process is over. Here is the first coat of west applied.
  17. Cannonman
    Hermitage, Tn
    More pics:
  18. Cannonman
    Hermitage, Tn
    Here it is after a light sanding and another coat of West Systems, I know most guys try to keep the amount of epoxy to a minimum, I prefer to have a nice glass smooth surface, so I put on an extra coat to give me something to sand dead flat without getting into the fiberglass. That is my Uritski hull (Russian Orfey class destroyer) along side:
    Lou likes this.
  19. Cannonman
    Hermitage, Tn
    I just found a few more pics of the fiberglass while in process, I must have paused to get a couple while mid way through the epoxy application:
  20. Cannonman
    Hermitage, Tn
    And here is one shortly after I started sanding the first coat of West Systems:
