Functional Minesweeper?
Discussion in 'Research and Development' started by DroBlue, Mar 16, 2016.
  1. DroBlue
    DroBlue New Member
    Texas
    Has someone actually built one of these that can actually sweep mines (I have been reading that mines are not used but still I think it would be cool if it worked)
  2. Hovey
    Hovey Admiral (Supporter)
    Washington
    It would be pretty easy. A traditional mine sweep is nothing more complex than a cutter that is pulled outward by an otter board and suspended at depth by a float. So for scale one of those safety letter openers on a string, with a float and a few other bits. The harder part would be making mines that float at the correct depth below the water.
  3. DroBlue
    DroBlue New Member
    Texas
    Interesting would a Paravane work?
  4. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    I will be happy to enlighten you about minesweeping. I am a USN Mineman. Name a sweep type and I've helped stream it:)
  5. buttsakauf
    Garland, TX
    Paravanes and otters function similarly. Both would probably not scale well. But only testing would tell.
