Futaba 9c
Discussion in 'Electrical & Radio' started by rcaircraftnut, Jan 7, 2016.
  1. rcaircraftnut
    Oklahoma
    Has anyone modded one of these to use push button firing? I have 2 of them and rather than buy a new tx, I'd like to use one of them. Other one will remain my dedicated aircraft radio.
  2. SnipeHunter
    Maybe, I've done button mods on a variety radios. If your just replacing a stick/gimbal with 4 buttons it is pretty easy, just building a voltage divider to change the voltage being feed to the control chip in the TX.
    The schematic is on this site somewhere, or try the SAS site (www.southeastattacksquadron.org) or probably a few other places. Sorry I don't have it handy to post.
    All you need is some good buttons, a few resistors, and some a hunk of wood to hold the buttons in the radio. If you're at all comfortable with electronics and soldering it is a pretty quick mod.
  3. rcaircraftnut
    Oklahoma
    I am actually quite good at soldering, I used to be a Navy electrician and can even do pcb's
    Just not good at design, if I have a print to go by though, I can wire anything.
  4. irnuke
    Retired EM1(SS) here. Bunch of sub electrician's in the hobby
  5. rcaircraftnut
    Oklahoma
    I was up for EM2 and a Senior Chief refused to sign my eval due to my refusal to sign a re'enlistment, so I left. If he had let me take the exam I would have made increment as I did on the EM3 exam, best score Navy wide for the cycle, 100% and was the only one to do it that cycle.
  6. WillCover
    WillCover -->> C T D <<--
    Harrison, Michigan
    Me, FC2 destroyer and tenders ,My son EM1(SS) sub :rolleyes:
  7. Iunnrais
    Iunnrais Active Member
    Texas
    Been using my 9c for boats since 2003. It's been retrofitted with a spektrum module and firing buttons. I actually got smart and set it up with swappable right gimble/buttons. I added a 4 pin mini deans plug to the connections for the right gimble rather than hard soldering the wires direct. That way, if I want to fly, it is simply a matter of unpluging the buttons, couple screws to change out the physical buttons for the gimble and plug in the gimble. It's a very simple modification. We used the same general layout of switches/resistors that are in this article: http://www.scrapcombatships.com/articles/howto/BE-radiomodvg600.html
    White is +5v
    Yellow is Elevator signal
    Blue is Aileron signal
    Brown is ground
    I'll see if I can find a pic of the inside of my radio for you.
    edit: added in the wiring color details for the 9c (at least for mine)
    Tugboat likes this.
  8. rcaircraftnut
    Oklahoma
    Thanks, that will help.
  9. Iunnrais
    Texas
    Didn't find any stored on my computer so I popped the back off and took a shot. You can see that the wooden plate needs to be multilevel to cleanly fit in the same space as the original gimble. Mine is all 1/8" plywood. The buttons mount to a circle that's the same size as the gimble opening. There are little 1/8" thick wood pads between the circle and the mounting plate that the screws go into to make the height right.
  10. Iunnrais
    Texas
    Finished product: All of the trims still function too so you can fine adjust the throws for different brand switches (or servos if you go old-school). I really like having the dean's plug in there so that I can swap between gimble or buttons at will.
  11. rcaircraftnut
    Oklahoma
