German Battleship Gneisenau - IRCWCC Rules
Discussion in 'Warship Builds' started by absolutek, Jun 23, 2010.
  1. absolutek
    Having battled a Scharnhorst that belonged to an OAF (Ontario Attack Force) member all of last summer, I decided last fall to order my own. Unfortunately due to college I haven't had much time to work on it until recently. I will be building mine as the sistership Gneisenau, to IRCWCC rules. It will be a 5.5unit ship, with a 1.0 unit pump, 1 x 1.0 unit 50bb cannon sidemount, 1 x 1.5 unit 75bb cannon sidemount, and dual 1.0 unit cannons on the stern (subject to change).
    This is everything I ordered from BC. The Gneisenau hull, deck kit, rolled plans, main/secondary/aa turrets & barbettes, rudders & posts, props, shafts, 1.0 unit pump, 540 size motors, wiring,some free balsa & silkspan and some other misc stuff.
    Unfortunately the ship came with Scharnhorst plans, but luckily I have been able to collect a wealth of info & pics on some of the differences between it and Gneisenau (including the hanger, masts, and bridge).
    The Stern view shows a slight mold seam which will have to be fixed with some bondo-like substance to make it even again.
    Bow view showing some of the damage received during shipping.
    Inside the hull...
    This is where I am at right now, having just finished marking out all the hull windows. I am going with 26 x 1/4" ribs, and a 1/8" stringer for the armour belt.
  2. bb26
    Nice looking hull.
  3. Bob
    I looks like you're going to cut out too much of the hull below the waterline. You need to be 1" below the water line. The tape you've marked looks a lot lower, but could judt be the photo. Put about 27lbs in it and mark the waterline. Cut 1" down from there. You don't want to run this ship at max weight 28lbs is the most.
  4. absolutek
    You may well be right, which is why I haven't cut anything so far. The bottom line was based on the "scale" waterline.
    --Chase
  5. absolutek
    Stupid question, if use a 1/4" marked waterline, do I have to cut the windows 1" below the bottom edge of the waterline, from the top edge, or from the centre?
  6. SnipeHunter
    Bottom Edge of the waterline.
    Before you cut, I'd stick it in a pool or lake, and ballast it to max weight to make sure you can make a non-scale waterline... if it won't make it, you'd have to unsheet it and cut the bottom of the windows more, a real pain. Good insurance to make sure she can hit your intended waterline before cutting :)
  8. absolutek
    Well, it is marked for the scale waterline already, which is from what I'm told, already too low for max weight. I'm waiting for a nice day to take it back to the pond and remark the waterline.
  9. Jay Jennings
    Doesn't Scharnhorst have a stringer? The one I have does have one.
  10. Tugboat
    It has a visible armor belt, so it gets a stringer :)
  11. Jay Jennings
    Thought so, but I didn't see one taped out.
  12. Anachronus
    Isn't that what the blue tape is? It does not run all the way to bow and stern so can't be the waterline tape.
  13. Hovey
    Hovey Admiral (Supporter)
    Washington
    If that is the water line and he only went 1" lower then the hull of the ship is about 2" tall!!!!
  14. rarena
    No, that looks like the stringer taped out.
  15. absolutek
    the blue line marks the top of the armour belt, which is where the stringer will be. it is not the waterline.
  16. absolutek
    Subdeck/deck assembly glued together & clamp (some have been removed already). Subdeck/deck has been sanded to fit into the hull, but not yet glued. Also have the hole for the drive shaft drilled out. more pictures to follow when I find my camera again.
  17. Tugboat
    Hmmm... never seen them glued together outside of the hull, interesting. Looking forward to the build :) I still have a Big Scharnie sitting on the wall awaiting refit, also to IRCWCC rules.
  18. absolutek
    well, I understand that a lot of people seem to glue the deck so that it is stuck on top of the rim of the hull, with the subdeck glued flush with the top of the rim of the hull. I didn't care for that look, so i decided to glue the two pieces together outside of the hull, sand them to fit, and I will be epoxying them to the hull, deck flush with the top of the hull. One of the other guys in the OAF does something similar with his ships, and I really liked the way it turned out.
    --Chase
  19. rarena
    That's the way I glue my decks in also. For the same reasons.
  20. Tugboat
    I alway fit mine so that the deck is flush with the top of the fiberglass, I just do the deck and subdeck separately. The benefit of the way you're doing it would seem to me to save a bunch of time since you don't have to fit two individual assemblies. Might have to try that in the future.
