getting the paper off the frames
Discussion in 'Construction' started by jimmybeekeeper, Feb 4, 2015.
  1. jimmybeekeeper
    jimmybeekeeper Active Member
    ten mile tn
    hey guys what is the recommended method of removing the paper i glued to my frames as patterns?
  2. DarrenScott
    Depends on what you glued it with
  3. jimmybeekeeper
    ten mile tn
  4. jimmybeekeeper
    ten mile tn
    i wet some and rubbed it off works ok but leaves residue
    sanded some after i peeled what i could away works ok not fast tho
  5. absolutek
    You're going to have to sand it off after peeling what you can off.
  6. thegeek
    You have to waterproof the frame after you have it assembled so make sure the ribs are ready to accept West System Epoxy.
    After the frame is assembled it is a pain to work on the ribs and clean them up.
    So now is the time to make all clean and straight.
  7. Cannonman
    Hermitage, Tn
    I agree... Elmers isn't the most "removal friendly" adhesive to use to apply the patterns. For future reference, I have had reasonable luck with glue sticks. If you glue a few at a time and them cut them out soon afterwards, it usually peels right off if you don't wait too long. Others have used a couple different forms of spray adhesive and seem to have had good results.
  8. ish311
    ish311 Active Member
    North Central Florida
    if you just leave it on and are using epoxy not varnish not a problem. if you remove it and leave the glue residue on it you need to remove it all. same for using varnish.
    Beltsander does it every time :)
  10. jimmybeekeeper
    ten mile tn
    i seem t have a problem with scale from the last copys of the frames i made really starting to get annoyed
  11. Brandon Smith
    Brandon Smith New Member
    Does anyone use cardstock and just cut and trace the ribs onto the wood without having to glue it?
  12. thegeek
    I use heavy cover stock and it works well.
  13. Brandon Smith
    Thanks, just trying to forgo putting glue on wood where I don't need it.
  14. SnipeHunter
    Tracing the lines on with carbon paper works well.
