Heavy Cruiser Prinz Eugen's guns setup
Discussion in 'Weapons & Pneumatics' started by NASAAN101, Feb 12, 2010.
  1. NASAAN101
    OK,
    Now, with the pump, can you have it set so its alway on or is that a bad idea? what do you guys thing?
  2. crzyhawk
    Some guys do it, others don't like it. There are pros and cons
    Pros:
    You can't forget to turn it on
    Cruisers can change batteries between sorties so power shouldn't be a problem
    Cons:
    Uses battery power even when not needed which makes you change batteries more often
    If you need to clear a vapor lock you can't cycle power to the pump
    you can forget to forget to turn the pump on (biggest ship killer I know)
    motor gets more wear because it's used more
  3. JKN
    JKN Member
    I would say on/off or an automatic switch is better than always having it on because some times of pumps can burn/sieze up.
  4. NASAAN101
    thanks Josh,
    I wasnt sure, if it was better to have it on all the time! The mistake at fall regionals when i went last year, i was was looking at the pump on one of my friend ships, and all most got a mouth full of water!
  5. crzyhawk
    Honestly, what I would do is hook up an auto turn on switch so you can use a control to manually turn it on as well. That way if you forget to turn it on, it will come on automatically. If the auto-switch isnt working, you can always turn it on manually. It's a little more complicated, but the easiest way to make sure there isn't a failure.
  6. NASAAN101
    crzyhawk
    The mistake at fall Regionals when i went last year! I was was looking at the pump on one of my friend ships, and all most got a mouth full of water!
  7. crzyhawk
    Yeah I've had that happen too. Just saying that's something you could think about as well for setting your ship up. My very first sink was at 2004 IRCWCC NATS (in my first battle no less) because I forgot to turn the pump on while I was waiting for the second sortie to start!
  8. NASAAN101
    Michael,
    That was funny! But anyway, I was thing about the gun set up more, why cant i up one forward and two back aft?
  9. crzyhawk
    You can, but you will get sunk more often and it's harder to use. I just recommend against it.
  10. NASAAN101
    Mike,
    OK! i was only thing that, cause it would be easier for me! but anyway, what did you mean by This: I've had that happen too. Just saying that's something you could think about as well for setting your ship up. my idea, for the pump, is not going strait up, but going backwards, so it looks like she pealing! not the best way to say it!
  11. crzyhawk
    Some guys like their pumps out the side or the back to enemies can't see how hard they are pumping. I prefer straight up so I always know exactly how hard I am pumping, and thus have a good idea as to how much damage I have. Besides, a ship pumping hard blowing a pump stream 20 feet in the air looks cool.
  12. NASAAN101
    Mike!
    That was funny! Just don't stand over the boat, when She pumping, and you'll get a wet butt, doing it!
  13. JKN
    JKN Member
    Could Nikki mount two 75 round guns in the stern and the pump facing stern in one of the turrets so the pump could be used as a weapon?
  14. NASAAN101
    JKN,
    I don't know if you can pump as a weapon! But the BC gun kit! 3 Unit for Des Moines, Adm. Hipper Large Class 3.5 ships (3 mounted aft - Triple fire)! But i dont know if you can do the two 75 round guns in the stern!
  15. crzyhawk
    She's in the IRCWCC, it's illegal for her to split her units into 2 75 round guns.
  16. NASAAN101
    Mike!
    She can have 3- 50 BB guns, right??
  17. froggyfrenchman
    Yes
    She can have 3 50 round cannons.
  18. NASAAN101
    Guys,
    I know, All ships shall have barrels installed in all main battery turrets. But with PG, i can only have three wroking guns, right?
  19. crzyhawk
  20. NASAAN101
    Mike,
    What did you mean by this: it's illegal for her to split her units into 2 75 round guns. I don't understand!
