Help Bismarck warship build
  1. NASAAN101
    What about the center prop???
  2. gunsnrosesx
    gunsnrosesx Member
    if you look on your website you showed me with just the Bismarck it will tell you that the starboard side prop is the only prop to rotate counter clock wise or clock wise....(its the only prob that spins the different way haha) if im not mistaken.
  3. NickMyers
    Nikki, counter-rotating is a concept that applies to pairs of props. So for a ship with 3 props, the outboard pair will rotate in opposite directions, and the center prop will spin in whichever direction the builder installs the prop for. You can't 'counterrotate' a single prop because there is nothing for it to be in opposition to.
    If the ship had 4 props both pairs would be set up with each rotating counter to its mate.
    And for your LST, you shouldnt be 'thing about it' - it should already be set up that way and unless you want your ship to constantly pull to one side, you don't set a dual prop ship up any other way.
  4. NASAAN101
    Nick,
    That just shows you how new i am with all that!
  5. gunsnrosesx
    gunsnrosesx Member
    Nikki don't take offense but earlier on this thread u said u were always on the Bismarck website that you showed me, i thought u would have taken notice on the prop designs and what one was the odd one out it even tells you degrees and such.
  6. NASAAN101
    David,
    Ya, i know! But with three working props, its hard to do!! and this is sliding off topic for a minutes, but when he got hit with the torpedo, the One Rudder got stuck in the center prop, and that what had me worried, having all three working, you know!!
  7. gunsnrosesx
    gunsnrosesx Member
    have you ever thought that maybe one of the rudders was turned when the 2nd rudder was stuck? and even if the middle engine blew the 2 would make up for it because the starboard is the only rudder on the Bismarck that turned the opposite way. and its also what Nick said earlier about having 2 props having 1 turn the opposite way to keep a straight line so what i think hes saying is that you should of already known and done that. Either way saying for me every time i make a mistake.... Live and Learn
    and to the history with the rudder being stuck, that definatly sounds like a rudder problem not props
  8. NASAAN101
    Yes its possible, But If you look at the photos from the Site, that i gave you!!! But what they should have done was locked the rudders and try and turn with just the props!
    ya, the guy that i got my LST from, he had them going the same way, and my mom and I get going to Counter rotate them!
  9. mike5334
    Nikki, they did try to use the props to turn the ship after its rudder was jammed. Unfortunately, the props and/or engine power was not enough to steer the Bismark on a heading towards the coast where the ship would have been protected by aircraft. It was not a design flaw ... the Germans just never imagined that a rudder would jam in the first place.
  10. NASAAN101
    Mikey,
    And she paid that failure!!! That's all i was saying!!!
    David, How is she doing, and were you able to test the motors yet??
  11. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    Nikki;
    You can not just rewire the motors, the prop for the one you are reversing must be reversed pitched also. So.... you need to buy a new prop for that engine.
  12. NASAAN101
    O ok!
    Like i said, I'm still new, even tho I've been to a few battles!
  13. gunsnrosesx
    gunsnrosesx Member
    Nikki they work amazing now i just need to set my esc so that only 7.5 volts goes to each motor so they don't burn up again.
  14. NASAAN101
    How far from being done is she??????
    Nikki!
  15. gunsnrosesx
    gunsnrosesx Member
    1% if you dont count me added cannons
  16. NASAAN101
    That's great!!!! its still a little on the cold side to take her out!!!
  17. gunsnrosesx
    gunsnrosesx Member
    haha yea i cant wait till ice thaws, last time i took her out the motors were glowing red an i saw smoke so i ran out to the middle of the pond, imagine how cold that was haha
  18. NickMyers
    Do your prop shafts spin freely? If they're binding at all on the bearing surfaces you will work the motors a lot harder. If you're using the oilite bushings I've found that you'll often need to open them up a little bit with a needle file.
  19. gunsnrosesx
    gunsnrosesx Member
    the props spin freely without binding
  20. gunsnrosesx
    gunsnrosesx Member
    ok guys i am now looking into cannons. i want 4 working cannons with a high fps and so i can rotate them as well. idc if its big gun or fast gun preferably cheaper route haha
