Help Bismarck warship build
  1. gunsnrosesx
    gunsnrosesx Member
    DKM Lutzow
    Dave what did you use to scribe in the decking?
    Dave if you ever decide to run your Bismarck in rough water you may want to check out the photos in the Axis in Rough Water! Bis can take it but make sure your pump is working very well and water channeling is very good .When Bis plunges water will go right over B turret so any open areas there will flood quickly. You don't want the bow to plow under. I sailed with Tirpitz in very rough water and Tirpitz's ballast was a little nose heavy, whcih unfortunaly caused it to plunge deeper and keep the water forward , end result Tirpitz went Titanic and wa veritcally then slipped quickly under. Wish I had a way to show you the video it is quite dramatic. The video is on a old vhs tape. The funny thing here is that the Lutzow was also with us and it porpoised quite nicely , again with the pump running all the time. The HMS Courageous ran quite well too but ti would rock voilently abreast of the swells. . We fought in this type of condition. Quite fun and scary at the same time.
    Bismarck handled well in the condition and was quite stable side on to the waves. You really learn how your model handles rough water and strong wind.
  4. gunsnrosesx
    gunsnrosesx Member
    Hey Curt i used pencil and a straight edge, lead pencil so i get a nice solid dark line then i painted the swastikas on then finally i coated the deck with spray polyurethane i coated it 4 times to make sure it had a good seal.
    As for rough water your not kidding i took her out again yesterday and the wind was blowing real tough but the bismarck took it well and it was really cool watching it blast through the waves and the water pouring off of it, i will probably invest in a pump at some point because i was out there for about 2 1/2 hours and i had a good bit of water in the hull. not to bad then yea i will need to make a water channel as i haven't already.
    Ok great thanks for the tip on the pencil lines. I used a sharpie marker fine point on mine. Yeah invest in a pump for your model even though it's a runner and probably better sealed than a regular combat model it's good to have one aboard just in case.
    2.5 hrs is a good long run. Glad your enjoying it.
  6. gunsnrosesx
    gunsnrosesx Member
    Haha yea oh yea Curt before you use the pencil make sure you hand doesn't run across the pencil markings because u will smear the lines and have to erase and do it over again so just heads up.
    Same thing with the sharpie rule. I will keep that in mind. Tks
  8. gunsnrosesx
    gunsnrosesx Member
    ok now i bring bad news. my 9oz co2 seal were the black tank meets the brass fitting, the rubber seal blew out so the question is will a 20oz tank fit in my bis?
  9. rarena
    Yes you can. It fits in mine. Way overkill but yes it will fit.
  10. gunsnrosesx
    gunsnrosesx Member
    eh with me i run out my 9oz to quick. hey can u give me the measurements of your 20osz please?
  11. CURT
    I can giive you the measurements of both the 20 oz and the 16 oz bottles.
    Dave refer to the A.R.C.C section under thread OB Bis Refit and refer to pages 13/16/17/18/22/and 35 to help you out also till I can get the exact measurements. I think the bottle is 3 in diameter, and a ft long I think.
  13. rarena
    My bottle with on/off valve is 11 inches long, 3 1/4 wide and a diameter of 10 inches.
    Dave I found on youtube and through Google this documentary form 2010 of the Bismarck. Good cgi. Here is the link .
    www.youtube.com/watch?v=z-leCeiWXFo
    www.youtube.com/watch?v=VEhCk4IcIXY
    www.youtube.com/watch?v=pEG-6pAZMsg
    or you can download a either of these links
    www.imdb.com/title/tt1778296/
    www.1channel.ch/watch-2682687-Nazi-Supership
  15. gunsnrosesx
    gunsnrosesx Member
    thank you guys as i will be buying one from strike most likely
  16. gunsnrosesx
    gunsnrosesx Member
    Bad news for me and my bis, I cant afford a new 20oz Co2 cartridge as my BRAN NEW ENGINE that i just spent over $3700 on decided to blow a manifold gasket and a valve cover gasket making my timing off (very slightly) so there is my next project haha priorities first.
  17. NASAAN101
    Dave,
    i'm so sorry! what happy?
  18. gunsnrosesx
    gunsnrosesx Member
    haha to much happened my luck i was even being nice to the engine kuz my tranny is going to be replaced with a performance tranny and now this so ill get her fixed trying to shoot for this weekend. ill keep you updated as for the bismarck i found some money and ima send for the 20oz co2 today.
  19. NickMyers
    Dave, I'm guessing you are getting the bottle filled from someplace that does paintball fills? I would suggest obtaining a 20lb co2 tank and fill station to fill paintball tanks from it. They are horribly expensive new, but with some Craigslist hunting you can usually come up with one for under 100$. Condition doesn't matter too much since the first thing you'll do is take it to a welding supply place and swap it for a fresh full tank (for about 20-25$).. From your 20lb tank you can fill your 9oz bottle many times.
  20. gunsnrosesx
    gunsnrosesx Member
    haha thats an excellent idea i will look into it eventually but for now ill rely on the paintball fillers. thank you nick though for that advice ill keep that in mind.
    As for the bismarck i am adding more details and will be posting pictures of what i did to it.
