Help Bismarck warship build
  1. NickMyers
    'Large' pump, from either Strike or BC would do the job and be useful if you wanted to use it in combat later. Since you're looking at just pumping out minor leaks though, anything really will work, right down to the BC Micro pump. Bear in mind you generally need a depth of water in the hull before you can start pumping it out, usually 1/4 - 1/2" depending on the pump. If you don't have water channelling, this may be a considerable amount in a ship the size of the Bis.
  2. gunsnrosesx
    gunsnrosesx Member
    haha i had about 3/4 an inch at one point and i got scared it will tip it over so i figured it was time for a pump and i need to make a semi ok water channel still but im placing the pump in the stern aft of the motors
    No waterproofing necessary for the pinstripe.
  4. gunsnrosesx
    gunsnrosesx Member
    alright thank you curt
    i would like everyone to know im doing more antenna work to the superstructure and i just finished putting the last of the railings up. also i would like to inform everyone that the gold anchor chains have been changed to a more dark grey and it goes great with the ship.
  5. gunsnrosesx
    gunsnrosesx Member
    ill post pictures when im done but they will only be pictures of what i added
  6. gunsnrosesx
    gunsnrosesx Member
    hey i might be putting hull depth marks on my hull and i wasnt sure if the bismark had white or black
    What are those little thngs beneath the forward Radar , atop the armored conning tower made of?
  8. gunsnrosesx
    gunsnrosesx Member
    they are plastic pieces from a other model
  9. NASAAN101
    Hey Dave,
    She's Looking Great!!! When are you taking her out again???
  10. gunsnrosesx
    gunsnrosesx Member
    when i get the time im back at home and i work almost everyday so weekends are my best bet but i got lots of work to do around the house before i can go out
  11. Knight4hire
    Knight4hire Active Member
    Just looked at the photos of here sailing and must say that is one sharp looking ship!
    One suggestion, the flag on the bow is upside down.
    Great photos!!!
  12. gunsnrosesx
    gunsnrosesx Member
    the flag on the bow is actually always willl be that way due to the fact the flag is one sided because of how thin it is so the other side would be right side up.
  13. Knight4hire
    AH, then you need to do a port side photo shoot.
  14. gunsnrosesx
    gunsnrosesx Member
    haha yea i never really took that into consideration i was just trying to take the best photos as i could and to keep everyone aware my admirals flag for the bis came in yesterday so i will be putting it on her for final touches.
    What's left to add to the model?
  16. gunsnrosesx
    gunsnrosesx Member
    the admirals flag a pump and maybe some little stuff on the hull when im not scared to mess it up but after the flag and pump i can probably be safe to say it is finally complete and btw i love how your ship is coming out.
  17. NASAAN101
    Hey Dave!
    How is Bismarck Doing???
  18. gunsnrosesx
    gunsnrosesx Member
    its doing still need to order a bilge pump
  19. gunsnrosesx
    gunsnrosesx Member
    Does anyone know if there is a drss uniform for the bismarck? if so can anyone give me a link to some pictures thank you
  20. Tugboat
    Build the boat, then buy the brown pants!
