Help finding a radio
Discussion in 'Electrical & Radio' started by Wayne, Mar 18, 2020.
  1. Wayne
    Wayne Member
    Western Massachusetts, USA
    Hello all. I’m new here and please excuse me if you’ve gone over this before. I am trying to decide what radio to get for my newest build, a scratch build of a three masted topsail schooner. I’ve been asking around on other forums and someone suggested I contact this group.
    I am trying to find a radio that is programmable, has the capacity to run up to 20 models and most of all can be able to change sticks from spring loaded to ratcheted. I need to set and let go of at least 3 of the 4 stick functions. I’ve heard that some radios have a hatch in the back where “screws” can be turned to switch from the springs to ratchet but I can’t find them searching the net and my eyes are starting to go crossways! Can anyone here help me?
    Thanks for any help or advice given.
    Wayne
  2. Xanthar
    Xanthar Well-Known Member
    Upstate NY
    ZARUBA1987 likes this.
  3. Wayne
    Wayne Member
    Thank you very much! I’ll give hobby king a call later today.
  4. wdodge0912
    wdodge0912 Well-Known Member
    Doesn't matter
    I guessing you are controlling servos for the sails, and using it to set them and have them hold their position?
    The knobs on that can be set to any channel. if you notice, there is more knobs and switches than there are channels on it. I have the FlySky X version so I know that can be done. If those would work, it's quite a cheap and easy way to have 3 channels that don't recenter (the throttle channel being the 3rd).
    Mode 1 and Mode 2 are what side the throttle stick is on, mode 1 the stick is on the right, mode 2 on the left.
  5. Wayne
    Wayne Member
    wdodge, Thanks for the info. I called a company in Miami yesterday that sells FlySky radios. The tech guy said that he didn’t know of any radio in the FlySky line that would or could be made to not self center. In my quick search, I wasn’t able to find a phone number for FlySky so I could talk to them directly.
  6. wdodge0912
    Doesn't matter
    Lol. That's funny. I emailed Hobbywing about their 880 dual motor esc asking what to increase the turns to using dual motors, as their website suggests to do, and they had no idea either. Im using that in my ships, but also using it in my PT109 model and wanted to make it faster with lower turn motors
  7. Wayne
    Wayne Member
    Still trying to find a tech person at a factory or outlet that knows the answer for sure. I’m thinking they ought to man these places with members from these forums!
    By the way, are you a Dodge enthusiast? I play with 1930/31 Cadillacs.
  8. wdodge0912
    Doesn't matter
    I'm not, I'm a Chevy and recently a VW guy actually. My last name is Dodge.
  9. rcaircraftnut
    Oklahoma
    Any radio can have the self centering removed. Simply remove the springs from the gimbals.
  10. Wayne
    Wayne Member
    RC nut,
    I do realize that but then without the ratchets, they tend to flop around.
  11. Wayne
    Wayne Member
    wdodge...any relation? I used to run a yacht for Horaces’ granddaughter, Cee-Cee. Some interesting tails there!
    Wayne
  12. rcaircraftnut
    Oklahoma
    Hello radios don't use the ratchet either. They use a metal tab to apply pressure on the same can in the same way just without the knurling. Easy to add if you can find some.
  13. Wayne
    Wayne Member
    Dear “nut”,
    I have a Spectrum DX7 which I was told would work the way I wanted if I bought the little strips. I bought 4 so as to have a spare if I screwed one up. Once I received them, I find that it has no posts or holes to screw them in place. I tried to return them but sales guy says “non refundable” they are discontinued and they were happy to find a turkey to pay for them!
    Could be these might fit. Steel (maybe SS) with a pressed notch in the center. I’ve since been told by another tech guy at Horizon Hobbies that my radio won’t work the way I want it to, hence the search for a “ratcheted radio”.
  14. rcaircraftnut
    Oklahoma
    Should be the ones. You may have to take a gimbal apart and drill and tap it for the screw hole.
  15. rcaircraftnut
    Oklahoma
    Could also get a parts radio from eBay ECT and use the gimbal from it giving two ratcheting gimbals.
