HK-7X 2.4Ghz 7ch w/ 5 Model Memory TX & RX V2 (Mode 1)
Discussion in 'Electrical & Radio' started by NASAAN101, Aug 9, 2010.
  1. NASAAN101
    hey Guys,
    Dose anyone have or use the HK-7X 2.4Ghz 7ch w/ 5 Model Memory TX & RX V2 (Mode 1) radio? I was looking at this for Both Little Lutzow and Little Prinz! what do you guys thing? its it a good radio? here what it come with: 1 x 2.4Ghz transmitter, 1 x 2.4Ghz Receiver, 1 x Bind Plug, 1x Manual! my question here is what is a Bind plug? This would be my first radio, and one i would keep for a long time!
  2. djranier
    Frank F just got his about a month ago. We dry tested it on the bench after we waterproofed the receiver, everything was working good. Only issue with it is that it is a helo radio, with a Aero option. When using it in Aero mode it only has 6 channels available, not 7. And when you first turn the transmitter on, you must pull the throttle to max down to clear the alarm, then recenter the stick, before you turn on the receiver. Also the right toggle switch is the throttle cut off, if you have it turned on, the throttle gimble will not function, another safety feature for Helo's, I would just disconnect it inside to prevent hitting it by accident, and then wondering why my boat was not working.
    Also mode 1 is European standard, or for lefties, throttle is on the right gimble, instead of the American standard, left gimble.
  3. NASAAN101
    guys
    that was the first one i saw, they have a mode 2 one also! its The HK-7X 2.4Ghz 7ch w/ 5 Model Memory TX & RX V2 (Mode 2) also!
  4. djranier
    I ordered one of the 9 channel Turnigy's, for the same price, plus the spare receivers are only $8.99. Will not get it for about 2 to 3 weeks. But I see they are out of stock again. I waited 5 days, and then they came in again, but are sold out again within minutes.
  5. NASAAN101
    guys,
    Is that the best radio for a beginner like me? or are there other radios out there?
  6. djranier
    Spektrum makes a very nice 5 channel radio, available right here in the states pretty cheap.
  7. KeriMorgret
    Seattle, Washington
    As usual though Nikki, the radio should be your last purchase, after the rest of your boat is complete.
  8. NASAAN101
    keri,
    I know im just try to feel around and see what radio would be best, that all!
  9. battleshipnewjersey312
    battleshipnewjersey312 Member
    what would be a good radio for a NC.
  10. Bob
    At least 5 channels.
    Rudder
    Drive
    Two guns (Bow sidemounts)
    One gun (Trips)
    Pump (Can also be used for lights)
  11. battleshipnewjersey312
    thanks for the information.
  12. NASAAN101
    Guys,
    This is one, i'm still going to get!! Cause i can add light and time them with the pump!
  13. NASAAN101
    Guys,
    Can you time the pump and light??
  14. NASAAN101
    Guys,
    Other then my LST No!! there another radio, I was looking at two: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=15142, So let me know what you guys thing ok!
  15. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    And... you want a mode 2 not a mode 1 radio
  16. NASAAN101
    Marty,
    what is the Diffidence, in the mode 2 to Mode 1? I'm just asking?? I'm Right handing, and that's how I plan shotting the cannons!! and drive her with my Left hand!!
  17. NickMyers
    Which side the ratcheted throttle is on.
  18. NASAAN101
    Nick,
    What do you mean, I don't understand..
  19. battleshipnewjersey312
    Nick do you like running your Sufren?
  20. NickMyers
    Its fun, but I'm looking forward to having sidemounts this year. Upgrading to a battlecruiser.
