HMAS Canberra Plans?
Discussion in 'Ship Plans' started by Slyfly, Apr 24, 2015.
  1. Slyfly
    Slyfly Member
    Mountain Home, Idaho
    Here too
  2. dietzer
    dietzer Admiral (Supporter)
    Tugboat likes this.
    The wood is a bit bigger than you'll want to use for the ship itself... but you will need a box/crate for carrying it around to battles! :)
  4. NickMyers
    Or to build a stand.
    or a workbench
    or a stool
  5. Slyfly
    Slyfly Member
  6. Slyfly
    Slyfly Member
    So to scale the plans i need to take it to a copier and scale it up by making the picture larger?
  7. Beaver
    Yes, just make sure it's in 1\144th.
  8. Slyfly
    Slyfly Member
    How can I tell?
    The way I do it is using the width of the frames drawing. Find what the scale width needs to be, divide it by the width of the frames and that give you the amount to scale it by.
  10. Slyfly
    Slyfly Member
    Frames are ribs or are they something else?
  11. Tugboat
    frames are ribs
  12. Slyfly
    Slyfly Member
    Though so, that explains alot
  13. Slyfly
    Slyfly Member
    Thanks
  14. wfirebaugh
    wfirebaugh Well-Known Member
    El Paso Texas, USA
    for a full set of plans something I had done before, at a Kinkos I used to go to has a copyer that would copy full sheet plans for for say houses and such. I don't rember the size of the paper but it was LARGE tho and the paper in the machine was on a roll on the back side of the machine. run the legoned through key with the inch to feet key and use a ruller and take note of the legoned with the size meter to be come the size you need it to be then you run the hole set through then. you could shrink or blow a set of plans through the copy machine. hope if this helps. real life experiances hehe :)
