HMS Abercrombie Monitor
Discussion in 'Warship Builds' started by JustinScott, Aug 26, 2023.
  1. JustinScott
    JustinScott Well-Known Member
    I had some time to kill while waiting for parts to print.
    Name that hull!
  2. Beaver
    Looks like HMS Roberts.
    Here's one for you.
  3. bsgkid117
    Kearsarge
  4. JustinScott
    Ribs!
    notSoGnarly likes this.
  5. JustinScott
    JEEEEZ.... I figured that obscure of a ship would at least take some time to figure out. AMAZING @Beaver!!!
  6. JustinScott
    Backstory: WHY am I building a MONITOR?
    I'm building it for a scenario & for NTXBG loaner ships.
    The scenario idea is like capture the flag, but with two equivalent warships on either side of the pond. The objective is to sink the opponent's Monitor and nothing else counts. We are not counting holes, sinks, anything. The only thing that matters is to sink a monitor.
    The other idea is to simply get new captains on the water. These ships should be small & cheap and will be available at the pond site to get people on the water. Historically, NTXBG loaned out Liberty ships for people to tool around the pond; but I think something with guns is a bit more engaging.
    Now, the question is CAN I build this thing? It has two 1/4" cannons on board. Compared to Deutschland; it's much shorter and not as long, however it has some extra width to work with. The biggest concern is the turret, fortunately, the Abercrombie's turret just sticks out of the ship like a sore thumb. It's basically the same height of Deutschland's cannons, so my rotate system should still workout here too.
    We'll see if I finish it. For now, it's just a distraction while I wait for Deutschland to print.
  7. Beaver
    Roberts has been a long time interest of mine so don't feel bad. I like obscure ships. Model looks great.
  8. JustinScott
    Well, I'll bite... what caught your eye on her?
    Did you build one? Any tips?
  9. JustinScott
    Last update for the day; I need to get my 'real' day started.
    Added props, however, even with Big Gun Rules I can tell I need to extract some of that hull to make room for the props.
    The props have a bit of an angry face to them. :)
    Screenshot 2023-08-27 at 11.12.29 AM.png Screenshot 2023-08-27 at 11.13.13 AM.png
  10. notSoGnarly
    notSoGnarly Well-Known Member
    I think monitors would be interesting for use as floating "shore" batteries. But for fast gun I'd want to be able to fully rotate on x and y axis. Which is an issue for our rules.
  11. JustinScott
    Yeah, I don’t understand why class 3 & below can’t have side-firing cannons.
  12. Beaver
  13. JustinScott
  14. Kevin P.
    Panzer and JustinScott like this.
  15. JustinScott
    Thanks!! I’d love to see some inside & below water shots of yours?
  16. Kevin P.
  17. JustinScott
    This is is great!
    I was today years old when I learned she has TWO rudders! I had believed she had just one from the plans. Amazing find!! No wonder she turns on a dime.
    Looks like 9 or 10 ribs? How thick? Any logic behind that count?
    I think I’m inspired to give mine a permanent down angle on the rotating cannons, like yours. I’ll just program a “don’t fire here” zone so I don’t shoot my deck off.
    Did you ultimately add weight to her sides? Did it fix the stability issues?
  18. Kevin P.
    the ribs at 1/4” thick, I probably looked at spacing to decide number but it was a few years ago so I forget exactly. Sheeting her is a PITA, I think I used like 16 pieces of balsa per side.
    I added some flat metal strips to underside of the buldges, it helped a bit, but she will still roll with water, just have to limit turning rate when significantly damaged, water channeling could be improved to fill the outboards more with slits for water to flow past
  19. JustinScott
    Progress!
    - Cleaned up the entire Hull
    - Created the deck & added the 'rails' to the deck
    - Thickened the hull to accommodate the props.
    Starting to look like a Battlestar?
    Screenshot 2023-08-28 at 10.56.27 PM.png Screenshot 2023-08-28 at 10.56.59 PM.png
  20. JustinScott
    Once again waiting for more cannons to pop out of the printer!
    So more progress has been made on Abercrombie!
    Rudder system is the same style that's been working perfectly on Deutschland.
    I find getting tools into Deutschland very frustrating, and I can't imagine trying on an even smaller ship. I've given her a tool-less motor mount; the test print seems to be very promising. We'll see if it holds up to a battle!!
    Since I hate working on superstructures, I figured I would get that out of the way. I also needed to know how much bonus space I had to work with... this thing's small!
