HMS Erin (IRCWCC/SJS)
Discussion in 'Warship Builds' started by Kevin P., Dec 17, 2024.
  1. Kevin P.
    The HMS Erin kit from SJS has been getting lonely on the bench, so I decided to put the hull together with some spare epoxy.
    Ever since Mike Mangus brought one to IRC Nats 2011 and won most feared it has been a boat I wanted to build.
    I planning to make a how-to video for the build as well.
    Anyways I glued the forward pieces together with epoxy, took about 45 min mainly because one set of fasteners were not facing the best way (which has been corrected)
    I glued the aft piece on with e6000 and installed the shafts in the same job, about another 45 min
    I put a yoga block up against the wall and used the block and hammer method for one shaft and drill for the other.
    Primary focus will be Vanguard but I’ll look to chip away at this when time permits
    Boatmeister, Nomercy and Beaver like this.
  2. Commodore
    Commodore Well-Known Member
    Sunny TX
    Wow, I totes forgot that was a thing. I'll look forward to seeing it ... someday.
  3. Kevin P.
    I had some extra epoxy mixed so got the magnets in and barbs. I used tape to get the magnets flush since they where a bit loose
    cleaned up after
    In all about another hour, so up to 2.5 hours total on the build
    vicious p likes this.
  4. Kevin P.
    Picking this back up
    I put the stringer rods in with plastic bonder, held with zip ties while drying
    also added bilge keels using my normal method
    Roughly 1 hour for stringer and 2 for bilge keels so up to 5.5 total
    bsgkid117, Boatmeister and Nomercy like this.
  5. Kevin P.
    Finished up the bilge keels
    added drag shafts
    Final of bilge keels
    And internal armor
    probably another hour on bilge keels and drag shafts, then 1.5 on internal armor, so now 8hrs in.
    Next up will be installing shafts and motors, then rudders to start other component spacing
    bsgkid117 likes this.
  6. Kevin P.
    Started on shaft install. going to try small 28mm motors
    going to use a Carl pump since the boat has the vertical outlet
    started on guns as well. It’s nice to only have to make 3 for this boat
    probably took 3.5 hours, so 11.5 to date
  7. mabgfounder
    mabgfounder Member
    Salem, Virginia
    I love that blast shield material! What is it? Where did you get it?
  8. Kevin P.
    It’s pet resistant screen, you can get at Home Depot/lowes/ace hardware
    mabgfounder likes this.
  9. Kevin P.
    More gun work over the past 2 weekends.
    I printed elbow holders and plugs for the stock barbettes
    added plugs on the unused ones
    T fitting
    time spend to fun barrels and barrel holders
    also made solenoid mounts. The aft deck will stay in place most of the time so flex mags and deck mounted solenoids. I’m going to try the strike solenoids I picked up awhile ago. The worked fine shooting a vanguard gun so I’ll try them here
    probably spent 12 hours in total so around 24 total invested so far.
    Next steps are gluing in the mag mounts and bottle mount, then I’ll drop in my modular control rats nest and should be close to functional
    Anvil_x and Renodemona like this.
  10. Anvil_x
    Yo so are you zip-tying them into that black cannon holder plug thingy?
  11. Kevin P.
    No, I’m adding normal printed mag mounts/holders, but with the black pieces and the barrel tip holders the things are pretty much in place
  12. Anvil_x
    interesting. no wobble whatsoever? I've never actually taken a close look at any of your cannon mounts in person. lol usually it's more of a "hahahaha he's not paying attention---OH GOD THE DUALS ITS THE DUALS RUN AWAY!!!!!"
  13. Kevin P.
    Yeah generally no wobble once they are locked in.
    I tested the guns this weekend, also test fit electronics (modular from other boats).
    I also duct taped the hull, ready to sheet
    trying to chip away daily and get it ready in time for NJ battle
    Anvil_x likes this.
  14. Kevin P.
    Progress update, I got the boat sheeted
    painting
    And fully painted
    also did a float test and added 2lbs of lead. The boat is generally ready to go, just need to connect air lines and turn on. The last update covered about 8 hours, this one probably 6 or so. Overall it comes to around 40hrs, though the electronics were just swapped.
    looking forward to first battle this weekend in NJ!
    bsgkid117 and Beaver like this.
  15. bsgkid117
    I can probably shave some time off your 40 hours, most of the kits are coming with integrated bilge keels now. Did your Erin have small recesses for the drag prop shafts to sit in on the hull? Because they come with that now too, vs needing to drill and glue and fill and such to mount proper drag shafts.
    -WT
  16. Kevin P.
    First battle is in the books! Overall success with a few things to tweak before next time.
    first some pre battle shots
    Pre battle weight was 19.5lbs. This was a bit heavy, I removed a pound and boat was sitting better
    internals with batteries, 4x 5000mah 3s LiPos.
    here is the battery tray, with 0.5” for puffing
    Now some battle shots. A ram I missed caused a sink in 2nd battle
    now some of the water Saturday morning
    Overall a solid boat. I had to bump up from 800kv to 2200kv, but ended at 43%endpoint forward so probably 1400kv would be ideal. Guns and solenoids generally worked, I needed to bump up from 12 to 18v as one locked up in 2nd battle. Maneuverability was ok but room for improvement that I’ll work on. The one combat damage sink the boat went down bow first, so I’ll add some waterchannel there. Other adjustments will be trim weights, then experimenting with different rudder shapes and possibly different props.
    Commodore, Beaver and bsgkid117 like this.
  17. Kevin P.
    Chipped away at the first batch of modifications
    Added waterchannel to bow and stern. Shaped the bow around the bottle
    stern area. Left space for pump ESC to fit aft of gearboxes
    now with tape and putty removed
    Also swapped out props for some directional ones I had lying around, and put on my traditional semi circle rudders, though the overall profile is not much different. A was able to extend props back 0.14” as well to get them further away from the stern cut-out. I made brass spacers on the lathe
    I think she’s about ready to retest, so I’ll try to make it to the pond next weekend to test out
  18. Commodore
    Sunny TX
    Looking good!
