HMS Hood
Discussion in 'Warship Builds' started by Nick Park, Jun 19, 2015.
  1. Nick Park
    Nick Park Member
    Got the 3 parts stuck together. Water channeling is in place. Now the stringers and fill in the holes at the bottom!
    Tugboat likes this.
  2. Nick Park
    Nick Park Member
    Done the stringers, now for a weeks holiday in Normandy :)
    Tugboat likes this.
  3. Nick Park
    Nick Park Member
    Can someone recommend which hardware kit I should use (strike models)
    The 4/5 unit kit is the same price as the 6 unit kit!
  4. irnuke
    Nick, I know you're in France, but are you building to (for example) IRC rules? Under that rule set (known as "Fast gun"), Hood is 6 units. so 5 guns allowed plus pump. So the Strike gun system would be BBSYST-5D ($290.00) for one twin-gun plus 3 single-gun setups for your 4 turrets. Then the fire control options are poppet valves (included w/ above) or solenoids & firing boards, etc. If you opt for the solenoids, Strike packages them with the guns under BBSYST-SOL-5D. Then you'd need three SOL-DRIVER-W-CONN firing boards to plug into your receiver and fire the solenoids.
    Hope this helps!
    (Keri, feel free to credit me the sales commission)
  5. Nick Park
    Nick Park Member
    Thanks Irnuke, I was thinking about the hardware kit for the motors and stuffing tubes etc :)
    However, I will be needing to install guns n stuff afterwards so thanks for the ideas.
  6. irnuke
    For drive hardware, this off-the-shelf would work: HDW-BB-ESC (I'd recommend using the ESC vs the micro-switch just for ease of speed control if nothing else). This also included the Battery Eliminator Circuit (BEC) meaning your receiver gets it's power thru the ESC (no seperate power wire needed).
    Prop diameter: I'd go with as big as you can get under the hull while keeping the shafts as flat as possible. The more down-angle you put on the shafts, the bigger prop you can get on there, but the props will be trying to push the bow down rather than the ship forward. So put the shafts in as flat as you can, then measure from centerline of shaft to closest point of hull. Double that and subtract 1/16". Now get the closest prop size smaller than that number.
    Example: 11/16" measured: 11/16x2-1/16=1 5/16. Use 1 1/4"
  7. Nick Park
    Nick Park Member
    Got round to doing the solid bits with balsa...
    and filing down the excess.
    Next is the sanding and the window height.
    I did the height slightly higher so I wouldn't have to add balsa.
    Finally a coat of fibreglass will be added
  8. Nick Park
    Nick Park Member
    almost finished the blocks of balsa, I've put the base wood for the channeling, it's wider at the bach as the pump will go there and more water will be collected here. I believe that when it gets to a certain weight, the back will be heavier sending more water to the pump making it more efficient. Any ideas?
    Tugboat likes this.
  9. NickMyers
    She's coming right along for you. Glad youve bounced back from the burglarizing.
    Nick Park likes this.
  10. Nick Park
    Nick Park Member
    Started the superstructure...
    I put thicher heavyer wood at the bottom (where the hits mostly go) and lighter balsa above. There is 5mm ply between each layer so hopefully not all of the structure falls off if it get badly hit!
    Eventually the post sticking up will be in copper so it can act as an aerial ;)
  11. NickMyers
    a lightweight fiberglass job will do wonders for damage resistance. Because my Derfflinger sits so low I 'glassed' the sides of the first level with a super light job of a dryer sheet (didn't have any lightweight fiberglass cloth on hand and didn't feel like cutting up something for cloth strips.) and some resin and its held up really well.
    Anachronus likes this.
  12. Nick Park
    Nick Park Member
    Thanks Nick, I was thinking along the same lines, something thin and light.
  13. Nick Park
    Nick Park Member
    I just realised something!
    Dryer sheets! brilliant!!!
    These are the fabric cloths one puts in the dryer for the washing?
  14. NickMyers
    Yeah, theyre supposed to make the stuff not all staticy. I just grab used ones when I need to do a quick and light glass job.
  15. Anachronus
    Plus they keep you boats smelling fresh! :p ;)
  16. NickMyers
    Must be one of those 4 in 1 benefits the box advertises
  17. SteveT44
  18. NickMyers
  19. Nick Park
    Nick Park Member
    looks like I'll be doing the shopping tomorrow :)
    I've got "personal buys" to do.
  20. NickMyers
    I haven't tried using an unused one before. The waxy fabric softening coating on it might be problematic, so you may need to volunteer to do some laundry too :)
    Or find an old shirt you were going to toss out and just cut strips from it to use rather than buy something.
