HMS Invincible refit
Discussion in 'Warship Builds' started by Tugboat, May 26, 2014.
    Darren, I used Goop on an Iowa hull and it was great, kind of similar (I think). It also reduces noise like you say :)
    Beaver, I will be using a Clippard hose clamp on the motor side, it's already pretty tight. The 1/8" propshaft is much smaller than the 4mm motor shaft, and so I need the clamping power of a collar with a setscrew.
  2. Beaver
    Ahh, I see. I want to do the same thing for my cruiser hence my curiosity in your method. :)
  3. Beaver
    They look very cool, and no I hadn't seen them! But I am sticking with the hose for now. It's even cheaper, and it's quiet as heck. Future boats may well find some of those fancy metal ones installed...
  5. PrepmasterNick
    PrepmasterNick Active Member
    Lake Charles, LA
    I wouldn't know which is better. I have the nylon ones in this Suffren I bought. I imagine the steel ones hold up well until they rust or need oil. Unless they're nickel? Maybe just need oil. If they spin at the right speed, I would imagine that any extra weight incurred would help with torque. That's usually true of flywheels and other weights on driveshafts.
  6. Lou
    Vac-U-boat
    http://vac-u-boat.com/KitsParts.htm
    Motor Shaft Coupling End for 1/8" shaft
    Motor Shaft Coupling Dogbone - Made of Acetal, a self-lubricating plastic. 1.3" long
  7. Lou
    Now with even better picture
  8. NickMyers
    Locally we've been moving away from dogbones. Too many snapped off and worn off nubs.
  9. PrepmasterNick
    Lake Charles, LA
    I would think so
  10. Lou
    ahh, but this has 4 nubs on each side, plus it is slef lubricating meaning a little slicker in the joint (I am channeling my inner shaft, can you dig it)
  11. irnuke
    <Isaac Hayes voice on>Damn right.<Isaac Hayes voice off>
    Lou likes this.
  12. Tugboat
    Collars arrived a day early! Nice surprise, and it means that I can test the driveline tomorrow!! I've got the electric heater preheating the shop so it's not totally frozen when I go out in the AM... The gas heater will get it toasty warm in no time.
  13. Tugboat
    Here's a shot of testing the collars today...
    Works very well, very quiet. All set for hunting wabbits...
  14. NASAAN101
    Clark,
    What motors are they?
  15. absolutek
  16. NASAAN101
    I guess what i meant to ask was are the brushed or Brushless motors.
  17. absolutek
    Nikki, from the first post:
  18. NASAAN101
    thanks chase, I'm not crazy About the Brushless motor, only because each one needs there own speed controller!!
  19. Tugboat
    Two brushless motors and two ESCs for them are cheaper than two $5 550-sized brushed motors and a single brushed-type ESC to run them. By a wide margin.
  20. NickMyers
    I'm not sure that comparing hobbyking escs to mtroniks is a very level comparison.
    Also... I can get a 40A Mtroniks Viper for 65, add in the two cans to make 75. The two HK ESCs will run 20 apiece for 40, plus 20 a piece on the motors, makes 80.
