HMS Puncher - Bogue Class CVT
Discussion in 'Warship Builds' started by canx2k, Jun 10, 2015.
  1. canx2k
    canx2k Well-Known Member
    canada
    Iron on tshirt transfers for signal flags ensign and of course since I'm a chaplain, the church pennant!!!
    tried to figure a way to keep the line taught while the mod poge hardens, rigged up a bead and thread for the spot and some loose thread for the ensign. Hope it stays!
    Boatmeister and notSoGnarly like this.
  2. canx2k
    canada
    Flags are up and brass crests are painted
  3. canx2k
    canada
    Looks mint
    Boatmeister likes this.
  4. notSoGnarly
    notSoGnarly Well-Known Member
    Those look awesome!
    canx2k likes this.
  5. NavyShooter
    NavyShooter Active Member
    Halifax
    Nicely done! The iron-on transfers are a great addition!!!
  6. NavyShooter
    Halifax
    Lou and Xanthar like this.
  7. NavyShooter
    Halifax
    First couple of modules are looking alright!
  8. canx2k
    canada
    hell yes it does!
    Have an eye for how high the pedestal is on the twin oerlikons - looks a bit high for the mechanized versions?
  9. NavyShooter
    Halifax
    Entirely possible. I'm printing the hull right now...we'll see how things look.
  10. Xanthar
    Xanthar Well-Known Member
    Upstate NY
    @NavyShooter , I was playing around with your stl files and I noticed that if one prints an extra copy of CVE_Hull_Pt_5_1-144.stl and adds it into the hull assembly, the over all length is very close to scale. There is some raised piping detail that'd need to be sanded off but, that'd be easy. A little bit of cutting and pasting would probably allow the flight deck to be expanded without much pain, too.
  11. NavyShooter
    Halifax
    I've got the ship *mostly* printed now, and yes - I think you're correct. I've jumped back into the 3D files and it appears that the hull OAL is 93mm too short.
    There is an even easier fix than printing 2x Hull 5's - I'm stretching Hull Pt5 module by 93mm, and stretching the flight deck by 93mm.
    notSoGnarly and Xanthar like this.
  12. NavyShooter
    Halifax
    OK. Unintended consequences...lengthening the flight deck by the required amount adjusts the position of the island by about 10 mm.
    Which makes the island support bars that are a part of Module 3 on the Stbd Side appear in the wrong spot.
    Easy fix - Module 3 gets lengthened by 10mm and module 4 gets shortened by 10mm.
    So, 3 modules to re-print.
    Xanthar likes this.
  13. Xanthar
    Upstate NY
    It's looking good. You'll be able to park a ton of air craft on the deck now.
    NavyShooter likes this.
  14. NavyShooter
    Halifax
    Thanks!
    My print queue is fairly long now...and this puts another 3 days on! (basically 1 day per module.)
  15. NavyShooter
    Halifax
    OK, so here we have a replacement for Module 5 printed, and it inserted into the line of hull modules.
    I still have to print the new Modules 3 and 4, but this is a better OAL now. I'm pleased.
    NS
    Xanthar likes this.
  16. NavyShooter
    Halifax
    Last hull module is on the printer now - it'll be done tomorrow at lunch. Then I can switch to printing the flight deck!
  17. NavyShooter
    Halifax
    Hull is now complete - printing the hangar modules, then I start the flight deck tomorrow!
  18. canx2k
    canada
    A buddy helping do the case
    Xanthar and NavyShooter like this.
  19. NavyShooter
    Halifax
    My Puncher hull is now assembled and I've started the sand/putty process to make it look somewhat pretty.
    Xanthar likes this.
  20. NavyShooter
    Halifax
    A bit of sanding last night, then another layer of putty over the hull to smooth things out some more.
