HMS Puncher - Bogue Class CVT
Discussion in 'Warship Builds' started by canx2k, Jun 10, 2015.
  1. Beaver
    Look'n good! 8)
  2. canx2k
    canx2k Well-Known Member
    canada
    Sand sand sand
    Nick Park and rcengr like this.
  3. NASAAN101
    The joys on sanding a wood hull :)
  4. SteveT44
    Nice work but next time, consider stripping it. You'll get fairer lines with less effort IMO.
  5. canx2k
    canada
    As in what, taking lo g strips and running the the length of the ship? I could only get balsa in 18" squares...
  6. SteveT44
    Yep, long strips. You can get basswood strips or if you have a table saw, easy to cut your own out of pine, cedar, or other bendy wood. Here's an example but I wouldn't use the little nails. I'd T-Pin them in place until the glue sets then pull the pins. Also note the forward frames in the pic were sanded (faired) to match the contour of the hull in that area. Not sure you did that on yours or not.
  7. absolutek
    Have you tried asking your local hobby store to order something different for you? I see there are several in the Ottawa area.
  8. canx2k
    canada
    It's already built in that respect, so I haven't bothered. I'm moving on to the other stuff (fibreglass, etc).
    I managed to pick up a 9x with receiver and an extra one for parts for $40, so that's pretty awesome.
  9. canx2k
    canada
    IMAG0809.jpg Waiting on the fibreglass, may as well do some decal design!
  10. canx2k
    canada
  11. canx2k
    canada
    did up a flight deck. Still gotta figure out how to make the tires more black. Deck4.png
  12. Time Lapse
    Time Lapse Member
    Vancouver Island Canada
    How much did it cost for the laser cutting for your ship ?
    Here is how I made cedar planking for my ship,Will sand smooth then fiberglass hull.
  13. NickMyers
    He bought the lasercut kit from @rcengr
    canx2k likes this.
  14. canx2k
    canada
    Yup. Got to some other stuff today, fitting the stuffing tubes and fibreglass end. Did some filling too. Next step, fibreglass the hull
  15. canx2k
    canada
    Got to sanding and glassing today. First time. Went....ok IMAG0947.jpg IMAG0948.jpg
    rcengr likes this.
  16. canx2k
    canada
    Little resin action for the inside
  17. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    Looking solid! A little elbow grease goes a long way toward making a wood hull look good:)
  18. canx2k
    canada
    Too had it being painted grey. Blaugh
  19. NickMyers
    Well, you can always go with crazy camo patterns
  20. Hovey
    Hovey Admiral (Supporter)
    Washington
    These ships wore a number of patterns. Several dazzle patterns were common as were patterns of shades of grey, all solid grey and even navy blue.
