HMS Puncher - Bogue Class CVT
Discussion in 'Warship Builds' started by canx2k, Jun 10, 2015.
  1. canx2k
    canx2k Well-Known Member
    canada
    Not done yet! Just finished the superstructure and notched each 6"x10' plank on the decking. Found theheights to be off a litle bit so I bought some 1/4" plastic to bridge the gap and make the removal easier as necessary. And lighter than wood too.
    And wintertime hobby which took my attention.
  2. canx2k
    canada
    More modelling after the move to west coast. If anyone is interested the twin bofors rafts and oerlikons are all available now in 144 scale on shapeways thanks to hawkins.
    rcengr likes this.
  3. canx2k
    canada
    After attaching the planking, I did the sides a little. Also, 16 books in print, bam. I got 2 of them circa 1945.
    rcengr likes this.
  4. canx2k
    canada
    Each 144 scale plank is 10ftx6inch scale, hence the butted joints all penciled and scribed by hand one at a time. 1000s of them.
  5. canx2k
    canada
    Here's the last ensign to fly on the puncher, mounted on my wall.
    NavyShooter likes this.
  6. canx2k
    canada
    Sponson sanding from blocks of wood to pretty and smooth. Kind of a shame to paint it grey.
  7. canx2k
    canada
  8. canx2k
    canada
  9. NickMyers
    Interesting way to layer up some extra detail
  10. canx2k
    canada
    After a bit of a hiatus, more cutting! Cut all the tiedown strips, mocking up the cardstock elevators before investing in the cuts of the styrene. And some end result styrene cuts. The triangle bits are the raft strapping.
    Beaver and NickMyers like this.
  11. canx2k
    canada
    Elevators!
  12. canx2k
    canada
    Other elevator cut out. I didn't like the rails so I yanked them and used the cameo to cut more accurately than I can with my hand and a knife. Each of the tiedown strapping strips have been cut out and will be filled with the 3d printed strapping once the deck is painted.
  13. canx2k
    canada
    Prepping for Optimus prime-er
  14. canx2k
    canada
    The hull was 'out of round' so a heatgun and some 'persuading' should balance it out
  15. canx2k
    canada
    I know what you're thinking, and yes; that's 250 bucks in 3d printed goods.
  16. canx2k
    canada
    I'm mostly impressed with the detail on the twinnies
    Panzer and rcengr like this.
  17. canx2k
    canada
    Some airbrushing the hull. Primer is important, it brings out the areas needing attention.
  18. canx2k
    canada
    The primer shows alllllll...and bondo is an excellent thing to work with.
  19. canx2k
    canada
    Let's try this again shall we? The first go around didn't have enough hardner. Man that was a lot ofshaving to getback to whereiwas
  20. canx2k
    canada
    splech. Notice the grey instead of the pink? Yah. Bad.
