HMS Roberts (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Jul 21, 2020.
  1. Kevin P.
    Refit on a ship built by Marty. I agreed to get her on the water. Back when I first looked into the hobby I wanted to build a monitor, so now that wish is coming true. Hardest part is done, the superstructure
    I think it was mobile at one point
    time to gut it
    Geek guns, they were still loaded when Steve pulled it off the shelf
    marking windows
  2. Renodemona
    I, too, had an interest in a monitor at some point but alas not yet come to fruition.
  3. Kevin P.
    Got her cut out today Most of the way
    also stripped some water channeling and pulled the shafts
    drew up a rudder mount to print, will get that going tomorrow
    bsgkid117, Nibbles1 and Beaver like this.
  4. Anvil_x
    Please tell me you are going to put hellish down angle on those guns and make it a drive-up murder-machine. you can get sidemount-level down angle out of those things!!
    *SO* glad you're doing a thread for this.
  5. wdodge0912
    wdodge0912 Well-Known Member
    Doesn't matter
    Too bad the HMS General Wolfe/ Hms Lord Clive monitors wouldn't be able to arm their fixed to starboard 18" gun, at least not as a side mount. would it be allowed to make it a Stern gun? I'm not sure how the rules work out for that.
  6. bsgkid117
    If you tried to do that, you'd have to say the 18" gun was the ship's main battery. Meaning you'd have a 3 unit boat with 1 1 unit cannon since there was only 1 18" gun in that fixed mount. I would think that the 15" guns, by definition, would have to be called the ship's secondary battery.
    Might be wrong. In reality, who cares. It's a monitor.
    Logan Gyre and acomputerdog like this.
  7. SteveT44
    When I first visited Marty's shop that boat was the first one I noticed. Marty was a great guy. I'm sure you will do Marty proud in this rebuild.
    Justin Ragucci and bsgkid117 like this.
  8. Kevin P.
    She might get down angle guns, TBD. that’s the goal Steve!
    More deconstruction
    finished cutting the hull
    Shaft realign
    Printed rudder mount
    Props
  9. Kevin P.
    More work done, test fit rudder servo
    Decided to reinforce stringer
    cut
    Need to redo some of the fiberglass deck to get better access to rudder servo
    ZARUBA1987 and Beaver like this.
  10. Commodore
    Commodore Well-Known Member
    Sunny TX
    ... Cute rudder gears - do you print those??? (If so, what/how/do you have the STL handy???)
    Nate G likes this.
  11. Kevin P.
    Yes gears are printed. I use the feature in fusion 360 to import part files from McMaster and modify as needed. I’ll post the files sometime soon.
    Progress over past few days
    Small BC pump mount
    bottle mount. Planning to try to fit the 3.5 in there
    Rough idea of internal layout
    Aye Blinken, Beaver and bsgkid117 like this.
  12. rcengr
    Nice. I didn't think anyone else would ever build this ship. Mine's ready to sheet, but I have a lot of work left. I'll post my superstructure files in case you want to use any of them.
    absolutek likes this.
  13. Anvil_x
    what's a decent source of plans, Mark?
  14. rcengr
    Profile Morskie is where I got my plans. They are nicely detailed.
  15. Anvil_x
    Oh ok cool. yeah I love their stuff.
  16. Kevin P.
    Thanks for the files, thankfully Marty took care of the superstructure
    decided that the cross member had to go for bottle access, really not needed from a strength perspective
    printed some rudders
    Put a layer of mat down and reattached deck rim
    Aye Blinken and Beaver like this.
  17. Kevin P.
    Coming together
    pump. tested her out, 1.2 gpm at 9A
    gun servo
    New deck pieces
    superstructure year fit
  18. Beaver
    Looking good, Kevin! Can't wait to see it in the water.
  19. Kevin P.
    Got her sheeted
    Not an easy task. Had to split pieces above and below stringer
    need to dial in the gun mounts
    she floated nicely, gluing mounts now
    Hopefully sea trials in the next day or so
  20. Kevin P.
    Got the insides together
    gun mounts, simple. Will need to tweak them a bit and hold barrel tips
    sea trials. Exactly 7lbs, might add some lead to bottom for stability in turns
    Z Boat likes this.
