HMS Vanguard (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Aug 1, 2024.
  1. Anvil_x
    SICK!
    thanks for sharing the link. yeah I was sitting there kinda like *huh, I bet that's probably a placeholder, but I should ask to be sure* because that servo has lower torque than the one I use in my class 5 boats.
    love the rough loft idea. that's a handy trick to have. one of the reasons I love wood and print is being able to do clean integrated mounts for stuff. cool to see that you can do clean mounts like that with just a rough measure, trim and go!
  2. Anvil_x
    Oh hey BTW I talked with BrianK today about those secondaries. I'm gonna do the CAD work for em, then send the file so he can foam cast some for us. I'll give you a heads up when that starts happening so you can get in touch with him
  3. Anvil_x
    Hey everybody, I just sent the STL file off to Brian K. if you need secondaries for your Vanguards, Brian can sell em to ya.
    Screenshot 2024-09-15 212234.png Screenshot 2024-09-15 212327.png Screenshot 2024-09-15 212401.png
    CURT and bsgkid117 like this.
  4. bsgkid117
  5. Kevin P.
    Able to get some build time in today
    I got the drag shafts in a couple months ago
    I worked on waterchannel today. Planning 1 pump forward and 1 aft. I decided to epoxy wood barriers in this time given the different features
    Front barrier for bow, the. Room for forward bottle, then fwd pump, mid bottle, aft pump
    going with 1/2” wide for most of the length
    stern area will be 1” to make a platform for aft solenoids
    I plan to use fetherlite to pour in the outer areas
    I had extra epoxy so I put rudder 1 together
    Justin Ragucci, bsgkid117 and Lou like this.
  6. Kevin P.
    Didn’t have any featherlite left so switched to subdeck today
    Traced onto wood. Hull is a good shape so beam was good/didn’t need any adjustments
    then I mark 3/16 to 5/32” inboard to account for hull rim.
    also drew in cross members and pump outlet holes
    cut out and good first test fit.
    forward outlet needed to avoid the superstructure, so further forward than I wanted but should work
    looking forward. Bow will be a separate piece. Planning to avoid a cross member around the motors , boat seemed fine stiffness wise. I’ll use a lip on the aft deck piece to make the joint between aft and mid pieces, aft piece will stay in place in most situations
  7. Anvil_x
    awesome work!
    yeah I was planning the new subdeck similarly with regard to keeping the fwd and aft deck plates in place and making the mags such that I could reload them with the center plate removed.
    Hey so with the bow bend, did you kerf the underside of the subdeck to get it to bend proper?
  8. Kevin P.
    The deck bends fine without need for cuts or anything
    I poured most of the waterchannel. bow was two part with the area around the bottle higher
    stern
    bow part 2
    I left the middle empty incase I need to add lead later, and it can be filled with the deck in
    I cut the bow porting of subdeck and then glued them together in the hull so alignment would be good
    just used 1/8 ply to bridge the pieces, they get glasses into the hull so strength is not a big deal
    next step is tracing and cutting out the deck from 1/8 ply
    Anvil_x and bsgkid117 like this.
  9. Anvil_x
    Looks great! I'm really looking forward to seeing how that pump setup works out.
  10. Kevin P.
    I got the deck rim in today
    Traced from subdeck
    test fit
    I cut the large piece right at motor mounts. Plan is for aft piece with guns to stay in place most times
    stern
    bow
    drilled deck hold down holes
    prep for install
    much easier to install the deck studs now
    all clamped in place and epoxy drying
    stern view. The pieces of wood across the top aloe alignment with top of hull, then deck is clamped to that. I don’t use compression between the wood and side of hull to avoid lumps, the deck is slightly larger than the natural opening so there is enough residual pressure. I’ll fill in any gaps once the first epoxy batch dries
    bow
    Anvil_x and Justin Ragucci like this.
  11. Kevin P.
    Pulled the clamps, came out good but lots of cleanup
    cleaned up top edge and taped edge to fill gaps from the bottom
    stringer made it harder, I think I got most of the edge
    filled in under the outlet tubes
    I prepped the barbs in fusion. I’m glad the Brit’s went with 15” guns, I was able to just tweak the QE barbs and the turrets were already done. Hopefully going to start printing tomorrow
  12. Iunnrais
    Iunnrais Active Member
    Texas
    Fusion sounds so much better than when I built a pair of Vanguard supers. They pretty much broke me for building new stuff for quite a number of years.
    Kevin P. likes this.
  13. Kevin P.
    Progress on finishing up the deck rim
    Sealed from the top
    result of filling from the bottom came out nice
    printed the barbs and gluing them in. the bow deck is curved when attached so I fastened the deck while gluing them in. Barbs are held up with a screw through a cross piece, and blocks to the deck
    showing the bend
    aft barbs were easier
    bow single sidemount
    After dual guns
    Underside of aft deck. I doubled up the thickness to hold 4 guns and make an overlap portion for the mid piece
    one layer of fiberglass cloth on barb outside for enhanced BB resistance
    Excess trimmed off
    Deck rim sanded down and final coat over the whole thing
    I added magnets for the mid piece and between screw hold downs
    brushes out excess epoxy onto the underside of the deck pieces
    other things not shown include boring out the Forster breeches. Next steps will be magnets and epoxy coat of deck pieces, and then guns. She’s coming along
    Panzer likes this.
  14. Kevin P.
    I got the deck magnets in and deck pieces coated in epoxy yesterday
    bilge keels on today
    first epoxy job from the bottom
    hopefully can chip away at a few things this week
    bsgkid117, Lou and Beaver like this.
  15. Kevin P.
    Finished up the bilge keels this week
    Magnets for turrets
    started on guns. I added a backing piece on the elbow for the back feed threads to have enough to engage
    Here is set up for solder, getting the lower joint and the back piece in one go
    and complete
    elbows in their holders
    bow sidemount
    Ran some test fires on a different piston set up, trying out the recessed style
    Some quick hoses to test it out
    added adjustment screw to set piston height
    the gun did we’ll, cycles great and shot hard, 260fps at 130 psi without drilling the piston yet
    next will be be finishing the end caps and T’s for the guns, then mounting guns. All of the guts are coming from the Iowa so should come together quickly once the guns are done
    bsgkid117 likes this.
  16. bsgkid117
    Looking good as always
  17. Kevin P.
    I made the rest of the Ts and pistons.
    Placeholder gun barrels
    T, piston, spring, end cap
    the piston sits inside the T, drilled out with 1:16” hole
    inside of end cap
    assembled, top of piston right below the magazine feed
    hole in piston
    rest of the Ts assembled
    forward gun mounts
    aft gun mounts
    magazines in place. they can be filled from middle deck access, and go along outboards so the pump will be accessible
    showing what it looks like with deck in place. The plan is to leave the aft deck fastened down most of the time. The lack of a cross member in the subdeck makes this much easier, otherwise the magazine would need to be fed under it whereas with this the deck can come straight off
    Showing clearance for the end caps. I have to Dremel out a notch in the port side (marked in sharpie). Hose planning is important with larger ID hoses
    continuing with gun mounts over the next few days
  18. Anvil_x
    Hey Kevin, how'd you lay in that set screw in the cqap? did you just drill it underbore through the solder and then hand-thread the screw in?
  19. Kevin P.
    It’s 4-40 thread so I drilled a 5/64” hole then used a tap to cut the threads. I solder a brass disc about 1/8” thick to the bottom of a compression nut that comes with the Ts and elbows, so there is a good amount of meat to hold the hose fittings
  20. Anvil_x
    Dang. right on.
