HMS Vanguard (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Aug 1, 2024.
  1. Kevin P.
    Gun aimers made and test fit
    Had to make 4” barrels for the sidemounts
    Props from Ronny finally getting used. Added an M4 set screws and locktited on
    Boatmeister and vicious p like this.
  2. Kevin P.
    Working on a pump screen/strainer design to cut down on the clogging sinks hopefully. The goal is to increase the filtered surface area and flow patches that can get to the inlet. Here’s the general set of pieces.
    I made a substitute base for the BC pump to fix the vapor lock issue with the older style and to add more flow paths
    pump in the strainer
    side view, water should go through the whole surface and then be free to make it to inlet
    front is open as well
    Top plate test fit, holes in the top
    lip on the top plate
    Motor shield over the top
    the whole thing gets covered with window screen for a filter
    Prop shafts, motors and gears installed
    gearbox cover and motor covers
    I also worked on solenoid mounts, here is bow solenoid above the forward pump
    Forward bottle and reg checking clearance
    bow deck with solenoid mounts
    i used aluminum 1” L which gives a nice strong mount
    after solenoids are more crowded. Short hoses but 4x large hose guns
    placing more internal components. Battery holders and middle bottle, also probably power distribution
    forward bottle and pump, should be cleaner up here
  3. Kevin P.
    Screen over the pump
    Bottle mounts printed
    Midships
    bow mount
    should be bench testing tomorrow
  4. Kevin P.
    Internal armor in
    Testing out the guts, adding a few wires
    currently 32.5 pounds which I think is a good spot for the status
    Balance point is right on
    Close up, the sharpie mark is the goal under the bottle mount
  5. Commodore
    Commodore Well-Known Member
    Sunny TX
    Dang, look at you ... all industrious and stuff. :p
    I suppose I should put the stringers in my Mac sometime this week...
  6. Litch42f
    Litch42f Well-Known Member
    Nevada
    What adhesive did you use to attach the screen armor under the deck? Looking to use the same technique myself.
  7. Kevin P.
    I prefer to use Goop. In this case I used e6000 because I ran out of goop. e6000 is more runny so it can drip away from the target surface easier
    Adding screenshot of rudder size for reference
  8. Beaver
    Now do a Steve and print it at 105%. Lol
    Anvil_x likes this.
  9. Kevin P.
    Sides are on. Sea trials will be tough with frozen ponds around here. Contact cement still cures when cold outside
    Bottom painted based on window height, might need to be tweaked after float testing.
    Next up is superstructure and float, also need to test guns
    Nomercy and Lou like this.
  10. Nomercy
    Nomercy Well-Known Member
    Maryland
    Guns are over rated
  11. Anvil_x
    Guns *are* overrated, when you have the right touch.
  12. Kevin P.
    Time for superficial things
    Painted
    IMG_3561.jpeg M
    Superstructure printed
    sea trials. Looks good but needed to switch props to high pitch
    she needs about 4lbs of lead to get to weight. I put 2 lbs in the center waterchannel and left some boxes to hold more strips as needed, below batteries
    view of float spool. The middle and aft SS will be the float
    superstructure mounts drying
    my one point of detail on the SS
    Just odds and ends left, battle in GA on Saturday!
    Anvil_x likes this.
  13. Anvil_x
    Oh splendid work, can't wait to see it in person on Saturday
    You talk to BrianK about the Foamies or printing the turrets?
    Kevin P. likes this.
  14. Commodore
    Sunny TX
    Dang, she's lookin' good!
    (Man, I wonder if it's possible to get a plane ticket to GA...)
  15. Kevin P.
    First event is in the books, I had a great time down at the Georgia Feb battle. Great weather and good turnout with 13 boats on the water. Vanguard did well for a first event, and the list of improvements is small/minor
    picture just before departing, tripods added
    on the water, she looked great
    after Day 1 I removed about 3 lbs. she was sluggish at first and did better with the weight removed. here’s a picture from before the last battle Monday
    there’s a good bit of video footage, hope to finish my portion soon
  16. vicious p
    vicious p Well-Known Member
    Greensboro NC
    Boat looked great on the water and per the usual for your boats was a terror. Guns sounded mean and that boat rotated awesome to be that large. Good work.
    bsgkid117 likes this.
    I am looking for secondaries and main turrets for my Vanguard . Is there a link for Brian ?
  18. Anvil_x
    Hey Buddy!
    you can talk with @bkoehler about getting some foamies if ya like!
  19. CURT
    Ok Thanks
  20. Anvil_x
    Hey @Kevin P. how has the forward pump worked out so far? is it worth considering?
