Hobbywing 60a esc ?
Discussion in 'Propulsion' started by FishNHard, Jan 1, 2019.
  1. FishNHard
    FishNHard Member
    On these speed controllers I see that it has pin set up for either Lipo and Nmh . will these work at all with SLA batterys .
  2. WillCover
    WillCover -->> C T D <<--
    Harrison, Michigan
    Use the Nmh ,I believe Lipo is suppose to cut off at low voltage as to not damage your Lipo batteries.
  3. Kevin P.
    That setting is for the low voltage cutoff, what voltage are you planning? The nihm setting should work, but you should check the numbers
  4. FishNHard
    FishNHard Member
    I'm running 12v I have a pair of 18amp hour battery's and some 9's for the Iowa
  5. Litch42f
    Litch42f Well-Known Member
    Nevada
    Are you looking at the 1060 brushed or 860 dual brushed? I don’t think the 1060 can handle 12v.
  6. FishNHard
    FishNHard Member
    Tryin to avoid buyin a couple hundred dollars of new battery's when I have a bunch of SLA'S around
  7. FishNHard
    FishNHard Member
    Looking at the 860''s the BC carries
  8. FishNHard
    FishNHard Member
    my mistake its the 1060
