How to build a tapered pump outlet
Discussion in 'Research and Development' started by B24, Dec 12, 2008.
  1. B24
    B24 Member
  2. rarena
    Wow Danny, that is really cool. There is some interesting pump tech out there and I may have to give it another look.
  3. GregMcFadden
    Why doesn't the flow go right to left thru the nozzle above?
  5. GregMcFadden
    from a fluid mechanics point of view, at the downstream side of the orifice, the flow is in an unstable condition, with pressure increasing in the direction of flow. You need to be "gentile" to the fluid in this condition to prevent loss inducing secondary flows and separation from the surface... hence the long lead out. Upstream of the orifice, you are accelerating the fluid, meaning that the pressure gradient is negative in the direction of flow, which is a stable flow regime to be in, so you can be more aggressive with the changes in geometry...
  6. B24
    B24 Member
    So that means the way I have it set up is correct? (i.e. the best for max water flow)
    Danny
  7. GregMcFadden
    in theory... when you throw air into the mix it can get trickeier
