how to scale for 1/144? made easy, with chart
Discussion in 'General' started by wfirebaugh, Nov 3, 2014.
  1. wfirebaugh
    wfirebaugh Well-Known Member
    El Paso Texas, USA
    The question doesn't bother me seeing it asked in the fourms but I thought I would have this up for others so they would not have to ask the question about how to scale 1/144. Here goes it. Know how long your ship is in real life. If your not sure you can look up the Wika page for the class of ship, it should show in feet, Take the German battleship Bismarck for example Length: 793 ft, Beam: 118 ft, and Draft: 31 ft divide the feet numbers by 12 Lets use the Length for example 793/12= 66.0833333 the hole number "66 is your inches" while the decimal needs to be converted to a fraction it will be in decimal form so use the chart below for your fraction conversion I would go with the 1/8th because 7/64 or a 3/32nd is so small its almost unnoticeable so in math terms usually round up its up to you. I have a decimal to fraction conversion chart below for 1/144 scale.
    Bismarck:
    Length 793ft /12= 66.08333 = 66 in. 1/8th.
    Beam: 118ft /12= 9.83333 = 9 in. 7/8th.
    Draft: 31ft /12= 2.58333 = 12 in. 1/4th.
    Standard System Measurement Fractions
    Fraction ... Decimal ... | ........ .Fraction ... Decimal
    1/64 ........ .015625 .... .| ........ .33/64 ........ .515625
    1/32 ........ .03125 ...... .| ........ .17/32 ........ .53125
    3/64 ....... .046875 .... .| ........ .35/64 ........ .546875
    1/16 ........ .0625 ........ .| ........ .9/16 ........... .5625
    5/64 ....... .078125 ..... .| ........ .37/64 ........ .578125
    3/32 ....... .09375 ....... .| ........ .19/32 ........ .59375
    7/64 ....... .109375 ..... .| ........ .39/64 ........ .609375
    1/8 ......... .125 ............ .| ........ .5/8 ............ .625
    9/64....... .140625 ...... .| ........ .41/64 ........ .640625
    5/32....... .15625 ........ .| ........ .21/32 ........ .65625
    11/64...... .171875 ...... .| ........ .43/64 ........ .671875
    3/16....... .187 ............ .| ........ .11/16 .......... .6875
    13/64..... .203125 ...... .| ........ .45/64 ........ .703125
    7/32....... .21875 ........ .| ........ .23/32 ........ .71875
    15/64..... .234375 ...... .| ........ .47/64 ........ .734375
    1/4......... .25 .............. .| ........ .3/4 ............ .75
    17/64..... .265625 ...... .| ........ .49/64 ........ .765625
    9/32....... .28125 ........ .| ........ .25/32 ........ .78125
    19/64..... .296875 ...... .| ........ .51/64 ........ .796875
    5/16....... .3125 ........... .| ........ .13/16 ........ .8125
    21/64..... .328125 ...... .| ........ .53/64 ........ .828125
    11/32...... .34375 ........ .| ........ .27/32 ........ .84375
    23/64..... .359375 ...... .| ........ .55/64 ........ .859375
    3/8......... .375 ............ .| ........ .7/8 ............ .875
    25/64..... .390625 ..... .| ........ .57/64 ........ .890625
    13/32...... .40625 ...... .| ........ .29/32 ........ .90625
    27/64...... .421875 ..... .| ........ .59/64 ........ .921875
    7/16 ....... .4375 ......... .| ........ .15/16 ......... .9375
    29/64 .... .453125 ...... .| ........ .61/64 ........ .953125
    15/32 ..... .46875 ....... .| ........ .31/32 ........ .96875
    31/64 ..... .484375 ..... .| ........ .63/64 ....... .984375
    1/2 ......... .50 ............. .| ........ .1 ................ .1.00
    please let me know if you notice Errors in my chart could not post a Pic of the chart so I typed it out. web site would not let me let me?
    hope this was helpfull.
  2. NickMyers
    You should be wary of the rounding up thing, especially when considering beam. For instance, IRCWCC rules stipulate "The allowable error in the beam of a model ship shall be +/- 1/8? or 2% of the listed scale dimension, whichever is greater. " For your beam example, 9 7/8inches would be a better number to round to than 10.
    Not sure what you have going on here with your draft math.
  3. DATDAVFred
    DATDAVFred Member
    cincinnati ohio
    Nice, thanks, for posting
  4. wfirebaugh
    El Paso Texas, USA
    Mathmatics teachers say round up. that was my thought process aney how when I wrote this and besides aneything shorter then 1/8th of a inch is a mynute ammount of mesherment so I would round to the 1/8th sorey afterr I posted this I went on a unexpected class trip for a few weeks TXANG.
  5. gunner250
    gunner250 Active Member
    Missouri
    What about weight?
