I- 400
Discussion in 'Warship Builds' started by Z Boat, Mar 8, 2020.
  1. Z Boat
    Z Boat Well-Known Member
    Roseville California
    I am building an Big Gun I-400 that will be ready this spring for testing. It has four 1/4" single shot torpedo's and a ballast system that is for positive buoyancy so i can sit on the bottom and let them forget where I am. It will have two bottom access hatches and I will only need to open one to get to the battery's ( 6 screws). IMG_1188.jpg IMG_1190 (2).jpg IMG_1205.jpg IMG_1206.jpg IMG_1211.jpg IMG_1214 (2).jpg IMG_1217 (2).jpg IMG_1208.jpg
  2. Julian Barbera
    Julian Barbera Active Member
    SF Bay
    Now that you say it I'll make sure not too!
    Build is looking great! How much do the vacuum formed parts weigh in comparison to traditional Balsa or 3D printing?
  3. Z Boat
    Maybe 3/8 ounce ?
    Julian Barbera likes this.
  4. Z Boat
    IMG_1220.jpg IMG_1219.jpg I would say less than a 1/4 ounce
    wfirebaugh and Julian Barbera like this.
  5. BigGunJeff
    BigGunJeff Well-Known Member
    Can't wait for.you.to.put.a bug hole in Joe's Iowa
    Nibbles1 likes this.
  6. BigGunJeff
    BIG hole I mean
  7. Nibbles1
    Nibbles1 Well-Known Member
    Orinda, CA
    I feel like our club has just become a giant "kill Joe" club.
    Kitakami should be fine... I mean same country same time right??? You won't shoot me right???
  8. Z Boat
    There are bigger fish to fry. About Iowa bigger.
  9. Kotori87
    Off to a great start. I also like the idea of a static diver for Big Gun. Will you be using fillable tanks and gas pressure for diving, a pump-and-bladder system, or syringes and servos? I also wonder if those MJV valves will have enough airflow to push a pair of 1/4" ball bearings up to speed. They're great for a single barrel, but they've always struggled when it comes to twins of any size.
  10. NickMyers
    this is being great, but why are pictures so tiny?
  11. Nibbles1
    Orinda, CA
    I volunteer to help!!!
    Just a few things.
    1. Subs have bullets
    2. He has made a tiny U boat before, and that works fine.
  12. wfirebaugh
    wfirebaugh Well-Known Member
    El Paso Texas, USA
    Like the Japanese, Burn the plans after construction lol :whistling: I'm happy to see a design being built, let me know of any design changes I should make. The front bow dive fins show to be larger or that size it depends on the resource referenced. the Conn tower is spot on :).
  13. wfirebaugh
    El Paso Texas, USA
    Will all 4 barrels fire at at once, or one at a time? I was just wondering I don't quite know or get the rules on this subject.
  14. Z Boat
    All four will fire at once for greater affect. The plans worked great and I used 2" O.C. rib spacing and not sure about the dive plane sizes, they seemed large. I have the center part of the hull for the ballast and you can see the reserve air tanks in the stern to empty the water. With a single shot an MJV 2 will punch big holes in a boat that does not have 14 coats of house paint applied with a mop just fine.
    Fixed
  15. wfirebaugh
    El Paso Texas, USA
    I will post a picture with the two different sizes for the forward dive planes. Reason why i had so maney ribs is if some one wanted to build a plug from the plans they could have a farley acurate hull shape if desired, and im just OCD about things I do. I would like to buy a conn tower from you if that is possible it looks really great. I atempted to build a plug with poster board, the shape looked great till I added the expanding foam that bent the spine of the ship in a giant "u" shape lol i was going to have a go at it again some time later to build a fiberglass hull when im done with O'Brien.
  16. Z Boat
    The bow planes in this pic are how I remember them.
  17. wfirebaugh
    El Paso Texas, USA
    The ones on the plans I got off of E-bay and are shown on the 3D model I made are way smaller
  18. Nibbles1
    Orinda, CA
    YAY ITS A MODEL MAGAZINE!!!
    Aren't you allowed to enlarge dive planes? I think I saw that in the rules.
  19. wfirebaugh
    El Paso Texas, USA
    May need to ask someone else... I have no idea, I was just letting you know what I knew that I had seen bigger ones. The ones in the magazine are easley double the size of the ones in the line drawing. /Shrug shoulders.
  20. Z Boat
    TY for the help.
    wfirebaugh likes this.
