IJN Mutsu - The Beast from the East
Discussion in 'Warship Builds' started by McSpuds, Nov 19, 2011.
  1. McSpuds
    McSpuds Vendor
    Louisville, Ky
    RE: IJN Mutsu 7yr build project
    My favorite ship, the Viribus Unitis.. :D
  2. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Cutting the new deck height here is going to be a serious pain......
    I am going to post a drawing tonight and have somebody look at it to make sure I am correct before I cut up this deck....
  3. jch72
    jch72 Active Member
    RE: IJN Mutsu 7yr build project I just posted the missing construction pics from July that show the hull windows cut out in my Nagato build thread, maybe they will help. For some reason I thought I had already posted them.
    Ron Hunt
  4. McSpuds
    McSpuds Vendor
    Louisville, Ky
    thanks. I just made a new thread for decks. Check and see what you think. I need Tim to look at them if possible.
  5. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Building has been at a halt the past couple of days as I have been under the weather. Turns out, today my doctor tells me I have Strep Throat..... :crying:
    arghhh life is good with a school teacher as a wife and 4 kids.... somebody take me out back and shoot me!
  6. moose421
    moose421 Member
    RE: IJN Mutsu 7yr build project I feel your pain. My wife to is a teacher, one daughter and a son on the way.
    Get well soon.
    Kim
  7. McSpuds
    McSpuds Vendor
    Louisville, Ky
    For those who are following the thread, sorry for the delay. I had to either winterize my shop(garage) or move a large portion indoors to the basement area. I chose the basement, its heated.... :cool:
    We are now back u and building here at Spudswerks now. I have finished my wiring and fixed a small bug in my travere system for the Bruno Turret. Pics coming soon.
    Right now I am at a standstill and dam near put the Mutsu up for sale.... o_O I am fairly good at building. Three pole mast ase easy. The 6 pole support system for the Mutsu Pagoda is cusing me to loose what little hair I have left.
    Does anybody have a neat little trick in doing this? The angles in those poles are the issue.
  8. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Here is a very nice reference on the different decks of the pagoda.
    Model reference
  9. Bob
    RE: IJN Mutsu 7yr build project For Kongo, not as bad as Nagato, I cut all the deck levels out. Then drilled holes for the masts in each level. Then i glued everything together. Of course some of the holes, ok most, were off. But a long drill bit took care of that. I was a little suprised how close I was this way.
  10. jch72
    jch72 Active Member
    RE: IJN Mutsu 7yr build project Followed your link on superstructure levels. Wow I wish I could get that guy to do my superstructure! Too bad I don't read japanese, looks like a nice site but babel fish choked on it. He was using miyukikai plans.
    Ron Hunt
  11. McSpuds
    McSpuds Vendor
    Louisville, Ky
    For those who are following this build, sorry for the lack of posts lately, the Secretary of the Navy (WIFE) :whistling: shut down any developments over the Christmas Holiday. Plus I had to move the shop in out of the garage as the temps are dropping enough to make my old bones hurt.
    I have moved indoors into the basement now. Shop is smaller and my major tools like the table saw, sanders, ect are still out in the garage. I did manage to get three work benches and most of my smaller stuff into the basement. I luv heat!
    Click here for larger photo
    You can see the SMS Baden in drydock to the right and the IJN Mutsu in the background.
    With funding approved by the Sec of the Navy, construction has resumed.
    The first thing on the calender was redoing my linkage in the rotate. We now have a very simple, sturdy rotate. The gun elevates and depresses on its own as it travels over the lower turret so there is no need for a elev/depr servo. I use a spring to keep the gun depressed and to keep it depressed while firing. The spring is just loose enough to allow the gun to elevate when I traverse over the lower turret. I also changed the push rods and it now has only one of the rods you see here.
  12. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Work on the Pagoda work began this week. With Jeff on the video cam with me to give me moral support I began the dreaded work. The main reason the Mutsu has been in the shipyard for 7 years now is because of the Pagoda. I have made some very nice masts in the past, even a very nice scale reproduction on the Arizona's cage mast. The Mustu's 7 pole pagoda is clearly the most difficult thing I have ever done.....
    Progress started out slow, and of course by the time you come to the end you have discovered several neat tricks along the way. I sure wish I knew of them at the start....
    I found the best way was to locate and drill the locations of the poles into the lowest deck. The I made a template of the upper most deck and drilled out the pole locations there. The template was then glued to the center pole to keep it sturdy while I constanly adjusted, repositioned, put together and pulled apart the decks one by one a thousand times till I got them all to fit. What I had to do was work one deck at a time. I would drill out the center hole, slide the deck onto the center pole, then slide each of the 6 outer poles in the top template and then visually align the poles to the bottom plate. Once alignment was ok, I marked the pole locations on the new deck and took it all apart, drilled the newly marked holes. Then place it all back together again to verify and most times... re drill holes till it was right. Rinse and repeat till all the decks had been completed. This process took days!!! o_O But in the end it is worth it because even though the splinter shields and a few other details need to be done, the pagoda is starting to take shape and looks very nice.
    Click here for larger view!
    The Blast plate and a few other things need to be moved into place better. I put them on to get the photo... :p
    Next will be the top two levels, a few sights, some windows, a little roof work, the range finder, and the splinter shields.
  13. McSpuds
    McSpuds Vendor
    Louisville, Ky
    At the local hobby shop I found some very thick plastic sheeting. 1/16" thick.... this stuff is great for the decks because it is just thick enough to make it very sturdy............. its like 20MM i think. And grey :rolleyes:
  14. mike5334
    RE: IJN Mutsu 7yr build project That is one of the nicest looking Japanese superstructures I think I have ever seen. Well done!
  15. NASAAN101
    RE: IJN Mutsu 7yr build project McSpuds,
    What kind of foam are you using??
  16. McSpuds
    McSpuds Vendor
    Louisville, Ky
    This pagoda is from one of BC's kits. He uses a 10 or 15lb Rigid Foam. Smoothon has it at 25.00 a set that goes a long way.
    I would recommend using Foam-it 15.
    http://www.smooth-on.com/Rigid-and-...index.html
  17. NASAAN101
    Thanks for that!!! She's looking great!
  18. gunsnrosesx
    gunsnrosesx Member
    RE: IJN Mutsu 7yr build project looks Great, and thank you for some of the ideas with turret rotation. keep up the great work
  19. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Just got my funding from the Secratary of the Navy (Wife) to finish the Mutsu..
    30+ years in the wood working areana, both for a hobby and some professional work for a few years... Let your guard down one second......:mad:
    After a few hours I decided to mix a few things together to see what I would get. I mixed up a dremel tool with steel cut-off blade, a pair of rubber gloves, and a heavy dose of stupidity.......:(:eek:
    Here is what came out of the mix................
    :crying::crying::crying::crying::crying::crying::crying::crying:
    I'm humble now.....
  20. CURT
    RE: IJN Mutsu 7yr build project OMG! How bad is it? Rubber gloves and a serrated dremel blade do not mix. I have had my fingers nicked many times but that dremel blade is scarey.
