IJN Mutsu - The Beast from the East
Discussion in 'Warship Builds' started by McSpuds, Nov 19, 2011.
  1. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Finished making the dual pump housing for the Mutt today..... Both pumps are on a autoswitch and one pump has a manual switch as well. One pump can be turned completely off/on with a switch. This enables me to change the battle units in just a few seconds.
    I can run either pump without having to deal with two different mounts.
    The Mutt has been put designed to have all her units already in place. She has both front turrets with sidemounts, four stern guns, and two bilge pumps. These units are already installed and working, all I need to do is turn off/on certain toggle switches and pin/unpin guns to change her battle configuration.
    She can run with:
    Four sterns guns - 1 front sidemount - one bilge pump
    or
    Four stern guns - two bilge pumps
    or
    Three Stern guns - two front sidemounts - one bilge pump
    or
    Two Stern guns - two front sidemounts - two bilge pumps
    all with just a few seconds of time needed to change pins and switches.
    Click here for larger photo
  2. Beaver
    That's wicked!!! :D I'll be avoiding you this NATS. :)
  3. absolutek
    Interesting, I would've thought it would be better to have the pumps in different parts of the hull (not that I know). You should post some video of it in action if you have time.
    I like this setup. Any plans to produce more.
  5. McSpuds
    McSpuds Vendor
    Louisville, Ky
    The impellers in this set up were made by Carl, and I can not use them in any pumps other than for my own use. But not to worry... Clark is making some impellers for them now on his 3D printer. As soon as he gets the impellers to me, I will make you one. Will you be at IRC NATS?
  6. McSpuds
    McSpuds Vendor
    Louisville, Ky
  7. NickMyers
    Looking good, I love your attention to the detail in the upperworks
    No chrysanthemum crest on the bow? I sense seppuku in your ship's future. :) :)
  9. ProfessorChaos
    ProfessorChaos Active Member
    Centerton, AR
    Just curious, why no haymaker?
  10. Tugboat
    I tried to talk him into it...
  11. misguided1
    misguided1 Member
    It ain't gonna matter much once I get onto the water, she'll be entering Davy Jones locker. :p
  12. Beaver
    I'd like to see that battle......:)
  13. Hovey
    Hovey Admiral (Supporter)
    Washington
    I guess some people really like their stern guns. Seriously though that is really nice work and I hope it performs well for you at Nats.
  14. jch72
    jch72 Active Member
    Haymaker and side mounts are superior in a large fleet battle but for a one on one against an opponent who turns better the stern guns will score many more points. Quad bow guns are much superior to either side mounts or quad stern guns when hunting convoy ships. It all depends on the battle situation.
    Ron Hunt
  15. McSpuds
    McSpuds Vendor
    Louisville, Ky
    I am using the LiFePo4 batteries now, and because of this, weight is a issue, I have to add weight to get my waterline and scale weight. So to make this easy, I added all the possible units the boat can have.
    The Mutt is configured with 8 battle units, 6 offense(quad sterns, two bow sidemounts), and 2 defensive(two bilge pumps) units. Of course I am only allowed 6 units at a time, so depending on the situation I will change what is pinned or turned on/off. I have her built this way to make it very easy to change those configurations between battles with very little effort... The guns of course are pinned, but because they use kips, I have a toggle switch on each one. This way I can turn on/off any gun with a switch. The bilge pumps are both installed, they just need to be turned on or off by a switch in the boat... If running both pumps I have the 1st one on a auto switch, and the second one on a auto/manual switch.
    At any time between battles (not sorties) I can switch to the following:
    1. Quad Sterns, One Bow side mount (can do left or right side), one pump (My Favorite) :rolleyes:
    2. Quad Sterns, two pumps
    3. Three sterns, two side mounts, one pump
    4. Two sterns, two side mounts, two pumps
    Or if feeling very cocky, I can use:
    5. Four sterns, two side mounts, no pump :confused:
  16. McSpuds
    McSpuds Vendor
    Louisville, Ky
  17. jch72
    jch72 Active Member
    Nice boat cart. I need to make one myself.
    Ron Hunt
  18. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Yea, I cant be lifting and carring that darn thing too much...
    Cost me 70 bucks in materials...
    The two wheels are lawnmower wheels, and I just drilled holes in a t-pipe fitting to attach them with 1/2" bolts.
  19. jch72
    jch72 Active Member
    Yeah I have to make a cart myself I can no longer lift and launch a 30+ lb boat after my back gave out last year. I was thinking about a cheapo $30 hand truck with solid tires (so it won't float) from harbor freight as the main frame for the cart.
    Ron Hunt
  20. McSpuds
    McSpuds Vendor
    Louisville, Ky
    It's fairly easy to build with PVC pipe.... the tires are solid lawnmower tires purchased at Home Depot..
    I drilled extra holes in the pipe all around so water will drain out and it wont float.
