IJN NAGATO PROPULSION
Discussion in 'Propulsion' started by CURT, Nov 6, 2008.
  1. CURT
    [:)]I was thinking of outfitting Nagato with 4 motors running 4 shafts. If I was to use direct drive what size motors would work for a boat this size? I think I will be using a ESC on this. If I do use an ESC with direct drive how many ESCs do I have to use?
    ADM STOKOMOTO[:)]
    Don't know for 4 motors, but I routinely run 2 motors with one ESC on my I-boat. What ESC (and what ratings) are you looking at using?
    Have no idea on the ESC but I think it's a Viper marine ESC? I was thinking of using this NAGATO as a runner. What ESC do you use on your I boat Tugs?
    ADM STOKOMOTO
  4. BoomerBoy17
    You could run all four shafts on 2 motors with BC 1 input, 2 output gearbox.
    Hmmmm that's an idea. I will have to look at that.
    Tks
    ADM STOKOMOTO
  6. BoomerBoy17
    no problem, im using one on my graf spee
  7. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    Curt;
    Why would you want to run all shafts? Sounds like it would cut down on turning ability?
    Marty
    Hi Marty. I am using this Nagato as Non combat so turning won't be an issue here. I am building it for scale and detail. Like to have it run all 4 prop.
    ADM Stokomoto
  9. GregMcFadden
    Curt, if you are going for scale, have you thought about building yourself two belt boxes rather than gearboxes? They will be quieter on the water and are rather easy to make.
  10. BoomerBoy17
    that sounds like it might be easier, esp if its only a model, not an RC NAVAL COMBAT MODEL
  11. GregMcFadden
    heck, I recommend belt boxes in general as they are, when constructed right, a bit more forgiving on the drivetrain when you hit dirt/rocks in the shallows and are quieter.
    Hmmm belt boxes. I am not a big fan of belts but for Nagato it may be doable as I wouldn't use it that often. I don't have the resources or knowledge base to build one myself.
    ADM STOKOMOTO
  13. GregMcFadden
    It is easy. Pick the right timing belt (sdp-si.com) with sufficient tooth height for what you are trying to do. Biggest issue is if you need a large amount of reduction... then they get too big. then make certain your motor can slide to take up the slack.
  14. BoomerBoy17
    Does anyone sell these, or do you have to make one yourself?
  15. GregMcFadden
    No one does that I know of. I generally make them myself. They are less tolerance sensitive than gearboxes which makes them a bit easier if one wanted to make it truly by hand.
    that being said, if you are running 550's heavily geared down, the gearbox is probably the better option. I tend to play with motors to find some that only need a little or no gearing down (or gearing up in some cases) so that I don't have the very high speed components in a ship that make some of the annoying noises.
  16. BoomerBoy17
    im not planning on making one. I am using a 1input, 2 output BC gearbox for my Admiral sheer.
  17. GregMcFadden
    that should work nicely.
  18. BoomerBoy17
    i really hope so, in fact im really counting on it to work well. I believe in Rick though, so i hope it goes well.
  19. CURT
    Thanks guys for the input. I think I have a good idea what I am going to go with.
  20. Gardengnome
    Gardengnome Member
