IJN Tone (formerly Something Silly)
Discussion in 'Digital Design and Fabrication' started by GregMcFadden, Nov 19, 2023.
  1. GregMcFadden
    I won't mention how many times I backed up and then realized yet again no Sterns...
    tgalx3 likes this.
  2. tgalx3
    tgalx3 Admiral (Supporter)
    Snohomish, WA
    But you are trying to change all that huh. ;)
  3. GregMcFadden
    new rudder is done along with a pair of breeches, one a few degrees down angle but full forwards, the other 14 degrees to stbd from dead aft this will just clear the superstructure. I aim to see if this off stern stern is less silly than the bows, and since changing is a 5 minute swap... if I don't like it I have the slightly down angled bows to go. I really like how the propulsion module turned out. it ended up being really easy to seal and then open up for service....
    Boatmeister and tgalx3 like this.
  4. GregMcFadden
    And now with long barrels.....
    tgalx3 and Boatmeister like this.
  5. tgalx3
    Snohomish, WA
    lookin sharp.
  6. Panzer
    Hell, MI
    Where do you load them at? and do you use 1 solenoid per gun or one solenoid for both?
  7. GregMcFadden
    They load under the silver turret and I used one solenoid per barrel. I have generally had good luck running up to two barrels off one solenoid but tuning it is a lot more difficult so if I can fit two I will do so
  8. GregMcFadden
    And now for details. I will do details this way more often. one base layer and print all the details on it then glue to ship.
    Anvil_x and NickMyers like this.
  9. GregMcFadden
    All right, well the offset Stern was less fun than expected. That was hard to line up. Next up offset bow.
