IJN Yamato
Discussion in 'Warship Builds' started by ish311, Sep 20, 2015.
  1. ish311
    ish311 Active Member
    North Central Florida
    had to fix an issue with the aft deck making extra solid area and just modeled up a fix and printed it rather than worry about how i was gonna do the hanger cutout later.
    Tugboat likes this.
  2. ish311
    working on building the full ss minus the turrets that i already bought. about 6 hours of work pulling details from about 3 sets of plans and adapting some things to 3d printing resolutions
    Tugboat likes this.
    Cool.
  4. ish311
    woof. 23 hour print for a test print of a parametric model of a yamato i found that was pretty darned good but just isn't optimized right so back to building mine again. ( what i have modeled will take about 8 hours and that seems to be about perfect per chunk for me.)
    Some of the cool models found online are NOT optimized for 3D printing, lots of polys.
  6. ish311
    test print came back a couple mm short in the second aa turret and with a badly leveled bed but it is about the single largest thing i can print.
  7. ish311
    going to test this to try reinforcing and positioning my solenoids in the boat. not printing the springs as they are just to weak printed
    and the update on the SS
    hull is cut but stringers need reinforcing and in some places rebuilt.
    Printed springs? For what?
  9. ish311
    not spring sprigs. lovely autocorrect. damned computer keeps converting my 1" to 1mm in the stl so i have to rebuild and convert everything to metric tonight..... sigh wish spartan built in metric so i could just use the plans without conversions.
  10. NickMyers
    What do you model in? Inventor happily lets me mix metric and imperial in dimensions so long as I specify the units that are inconsistent with the document settings. The export to STL function also has a toggle for target units.
  11. Tugboat
    It's really easy to convert before you work in the software... Especially for the few things that match up to SAE vs metric. I mean, for the Spartan,s it's like 2 holes, ja?
  12. ish311
    modled is plain old autocad. might export it into inventor. set it as imperial and worked in imperial but it's exporting in metric....
  13. NickMyers
    So everything is ending up small?
    If its converting to metric for the export, i'm afraid i dont see the problem? STLs are technically unitless, point space is in arbitrary units, most slicers that I've seen assume that the coordinates are intended to be measured in mm. If you're having a scaling issue are you sure Autocad is not exporting the original imperial units to the STL (and thus everything ends up about 4% of intended size) ?
  14. ish311
    should be 40.44mm long. just redid the export and ran it through a check and it is at 40.44mm something is off when i drop it into matter slice. but now that i know the dimensions i can just force the scale properly
    test came back and i need to mirror the layout. got the orientation wrong for the way i want the posts to set. might just screw in the solenoids to the plate and put a gate tab in the hull to make the solenoids easy to service but not gonna fall loose.
  15. ish311
    while sitting around waiting for parts and deciding how i was gonna put together the solenoids i happened upon maxspin's thread on the direct hookup solenoids........ I'm gonna get some parts and see if i can make that work. if so my entire gun deck will be super easy to remove for maintenance and damage checks. the elbows are on the way and i have the rest of the parts. and if it doesn't work i still have the parts to build them in the standard style as well.only thing that will be interesting might be getting all 3 guns in there with the rear gun. looking into that as well might just have to design something custom to use with the information from the current ant-farms just modified to have outputs where i need them.
    or not. if the elbow comes out at the same height that it appears to do so on maxspin's boat it should be the perfect height for the ant-farms to deck-mount as well.
  16. ish311
    first test fit of parts. still need to drill the mag pressure tube holes and cut the up tube copper but very very rough fitting is done.
    sigh got to the rest of the parts and somehow i have 2 very different parts under the same part number. one is a 1/4 x 1/4 and the others are 1/4 x 1/8... so now i get to try to send back parts.
  17. ish311
    very rough fit of the dual turret. will need to trim one of the barrels to make the other match and to keep them from hanging over any cause someone will decide that hugging my guns would be the best way to not get shot.
    used the exact same plate for the triple arangement as the double. will need to drill out the holes in the deck for the reload points but it fits rather nicely sofar
  18. Maxspin
    Maxspin -->> C T D <<--
    Yelm, Washington
    Looking good!
  19. ish311
    launch and carry rig is about 80% complete
    take three guesses on what the wheels are
  20. NickMyers
    Not very round. :D
