IJN Yamato
Discussion in 'Warship Builds' started by ish311, Sep 20, 2015.
  1. ish311
    ish311 Active Member
    North Central Florida
    actually not bad.
  2. Charley
    Charley Vendor
    Lancing, Tennessee
    Build is looking Good!
  3. jcollins
    jcollins Active Member
    Beavercreek Ohio
    I just started working on a Yamato, would you consider sharing your 3d models so I could print them for my ship?
  4. ish311
    certainly. once i finish them i will publish the solid file.
  5. ish311
  6. rcaircraftnut
    Oklahoma
    Very nice.
  7. ish311
    new triple mount that actually has been working rather well. will patch the old magazine holes.
  8. ish311
    Progress!!
    IMG_0748.JPG found a decent Yamato model that i could scale and slice up to print. only 4 more sections to go. or about 30 hours of printing. and once again my i3 change filament setting saved me. woke up about 3 hours into an overnight print (that bottom took forever) and i had may 20 feet of filament left on another 7 hours of printing.
    tomorrow it will get in place testing of all guns and solenoid and prop testing if all goes well... last 2 guns will wait until monday as the printer is occupied until then
    rcengr likes this.
  9. rcengr
    Nicely detailed superstructure. Can you share where you got the CAD model? Some guys in my club are working on a Yamato.
  10. ish311
  11. ish311
    progress
    switched back to regular guns as the BIC where running 40-42 rounds per load and was having issues with eating springs
    had a sheet of scrap 1/32 pvc coated aluminum laying around so armor
    installed the cooling pickups for the esc.
    90% of the aft is done. need to install the rudder servo still
    Need to install a bottle holder
    front is all done including wiring but the harness leads need extended as i moved the whole unit forward 6 inches
    Mk2 boat carrier. cut off the front and added two wheels. works nice and fits Kongo and Yamato.
    still needs finished gluing and some rope or something up front to drag it with.
  12. rcengr
    Any idea what was causing the spring issue?
  13. ish311
    excessive travel of the interrupter pin seems to be what was causing the springs to get destroyed. was having a hard time getting them to feed 100% of the time. only one of 3 guns that i finished would eat springs but that was enough to back burner until i can figure it out.
  14. dietzer
    dietzer Admiral (Supporter)
    That would seem to imply that either the interrupter pin is too short or that the piston cavity is too deep.
  15. ish311
    so begins the painful process of skinning. only took about 30 minutes to get that one side almost done
  16. ish311
    skinned and other than waterline mark painted!. need to install the secondaries and do a final electrical test and Yamato is ready for it's first failure.
  17. Renodemona
    Great looking super! Is the file on the resources here, or?
  18. ish311
    parts of it are in the resources here. but that one in particular is a rip of a yamato complete hull i found on thingiverse
    Tankman likes this.
  19. CURT
    I LOVE that Superstructure. Like to replace mine with that one. Nice work on your Yamato Captain.
  20. ish311
    And the Brushless ESC lost their little brains so to 770 cans i went. as well as replaced the firing board i fried and cleaned up wiring and CO2 lines.
    pipe clamp motor mounts are secured with a large amount of epoxy putty coated in west system epoxy after it dried good.
    more managable wiring harness some improvements could be made but for now it works.
    new Solenoids to replace the one that froze. mounted on a puck with a ziptie. worked better than expected
    double test switches are nice and clean
    messed up and overfilled my epoxy pot and made one connector non functioning. luckily i have a triple
    and bench testing is done! everything works! new solenoids are super quiet and the new motors are even quieter than the brush-less where and actually produce enough power. need to speed test and adjust ballast.
