Importing blueprints
Discussion in 'Digital Design and Fabrication' started by Lou, Apr 11, 2021.
  1. Lou
    Need to import 1/144 scale plans (they are over 6 feet in length), the goal is to be able to make parts in fusion360. I am thinking that regular scanners would not work (hard to keep the copies straight without inducing a bend). Is there a service that would digitize them (can the large printers at a kinkos be used to scan)?
    Looking to see if anyone has solved this before I do investigation. Plan is to follow Will's tutorial, but I need the plans on the computer first.
  2. bsgkid117
    You'd want to look around your area for any professional document scanning services, most of the time they'll have a large format scanner for doing this kind of job.
    If you are at a loss and cant find a place, maybe call your local construction / zoning office. See if they have started to digitize their records of old building plans. If they have, ask who they use.
    Lou likes this.
  3. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
    I used a Kinkos to scan in and print out 1/144 scale Iowa blue prints (so I had a copy to cut up).
  4. WillCover
    WillCover -->> C T D <<--
    Harrison, Michigan
    I uses to use the older flat bed scanners upside down on a table.
  5. Bob
    I’ve always used a scanner that can do 46” wide paper. But I also work for an electrical contractor so we have one in the office. We also have a couple of plotters to print stuff with.
  6. Commodore
    Commodore Well-Known Member
    Sunny TX
    Plans for what? Odds are someone already has them.
