IRCWCC rules question
Discussion in 'General' started by MasterClay, Aug 13, 2011.
  1. MasterClay
    MasterClay Active Member
    morris, illinois
    ok i have a quick question about impenitrability on a Mehoshi Maru, its about the solid area aloud at the aft section i know 1 inch is the max but i there a minimum? i've read Nick's topic in the plans section and i'm just trying to make it legal without having to leave out more ribs or moving and resizing what ribs i have left
  2. NickMyers
    far as i know, there is no minimum amount of hard area, but there is a min distance between hard areas. That was the problem I encountered. For my build I solved it by moving some ribs rather than reducing the hard area. If you're working off of my plans I believe the plans linked on my thread reflected that alteration.
  3. MasterClay
    morris, illinois
    thanks Nick, I didn't have your plans printed but i will get them printed and use them to solve the problem
  4. NickMyers
    one caveat on mine, I ended up cutting about 1/4" off the end of the skeg to make more room for the rudder and prop - I'm pretty certain this is not reflected on the plan sheet, you may find you want to make that modification as well, you may not
  5. MasterClay
    morris, illinois
    thanks again, i'll make sure to do that while i'm building
