Is water channeling neccessary?
Discussion in 'Construction' started by Captain obvious, Aug 14, 2016.
  1. Captain obvious
    Captain obvious Active Member
    Hastings, MI
    In the middle of a rebuild and this ship has never had a water channel. I have the room. Just wondering the necessary to install a water channel. I can see the benefits but are they great enough to add on?
  2. Maxspin
    Maxspin -->> C T D <<--
    Yelm, Washington
    What ship? Generally speaking I would put in a water channel, however on smaller ships you raise the center of gravity just that little bit.
  3. Captain obvious
    Hastings, MI
    It is a liberty ship.
  4. Maxspin
    Yelm, Washington
    unless you are going to run a pump, water channeling in not necessary.
  5. Captain obvious
    Hastings, MI
    Don't think it is within rules to have a pump for a convoy ship.
  6. NickMyers
    up to your local crew for non sanctioned battles
    locally we houseruled them ok (basically require that you use the BC micro pump only with a half unit restrictor). YMMV but we didn't like the idea that any leak was an eventual doombringer (we also did away with any halo rules, limit to attacking ships, etc)
