King Edward VII - Fastgun
Discussion in 'Warship Builds' started by Beaver, Oct 18, 2016.
  1. Beaver
    I'll be working on some improvements to this ship in the next few weeks. The main things I'm planning on are some gun tech improvements and a driveline upgrade.
    Today I built a better mount for the bow guns. I never really liked the ways I had mounted them in the past. I like this, but I still think I can do better.
    The turret and the AL angle part keep the barrels aligned and secured. If I want the barrels to tilt in I can print another turret with the openings wider apart.
    Hopefully I'll have more stuff to post soon.
    rcaircraftnut likes this.
  2. Beaver
    Tested the new guns in the boat today. I could say what I feel about them, but I made a video instead. :D
    View: https://youtu.be/pQfnlN9l6z0
    Pics of the new drive setup coming soon.
    WillCover and Kevin P. like this.
  3. rcaircraftnut
    Oklahoma
    Not bad. Looks like they work pretty good.
  4. Beaver
    The ROF wasn't as good as it could have been. The firing switches in my radio are of poor quality and I get inconsistent shot patterns. I plan to put better switches in, so that should fix that.
  5. rcaircraftnut
    Oklahoma
    Got to do a switch conversion on my 9c heli radio that is now my ship radio. Throttle/rudder gimble is busted so it's a perfect candidate.
  6. Beaver
    I like to use snap action switches in my radios. I find I can shoot faster with them versus push button switches.
  7. Beaver
    Since I had my first successful test of my new belt drive I think it's time I post a pic.
    It's pretty quiet and hopefully will be trouble free.
  8. SnipeHunter
    Cool, glad to see someone else trying one as well!
  9. Beaver
    Your build inspired me to convert mine. Except for some trouble trying to get metric pulleys to run center on 3/16" shafts I'm really liking it. It's going to be battle tested next weekend. Hopefully it holds together. :whistling:
  10. SnipeHunter
    Awesome! I'm excited to hear about how it does in battle and holds together. I need to make some more progress on my build but I'm in the middle of a bunch of other design work and only so many hours in the day. Good luck next weekend!
  11. Beaver
    Off to war tomorrow!
  12. Kevin P.
    couldn't find time to resheet this winter?
    (technically, by the rules, all old damage must be painted over before starting a new event)
    See you tomorrow!
  13. thegeek
  14. NickMyers
    Its the new camo pattern 'sloppy shaving'
  15. Beaver
    Well, the belt drive setup fared pretty well last Saturday. No issues really other than a motor pulley came off the shaft during a sortie. I think that was more of an issue with the setscrew fastener though, not the setup itself. All in all, I like the belt drive. It's quiet when set up right and seems durable. I'll be making some improvements in the next few weeks and then see how it fares at Carl's in May.
    On another note, I've been fixing some things that have bugged me since I finished the boat last year. I've never really liked how the bow solenoids were situated in the bow. Before I added an accumulator tank they were just thrown in the front of the boat and pushed out of the way when it came time to put the deck on. Not to my liking. I then put in an accumulator and that was better, but the way I had it situated, lying horizontal, took up a lot of space and interfered with the guns when I tried to put the deck on. I've now flipped the accumulator vertical and moved the inport to the bottom and this allows it to sit about an inch further up the bow. I soldered a brass mounting tab to it as well so now it is bolted to the hull and won't move or fall out of the boat. Much better! :)
  16. SnipeHunter
    Awesome, I'm glad to hear that the belt drive held up for you in actual combat! Hopefully that continues to be the case as you get some more use and age on it.
  17. Beaver
    One thing I'd advise when setting up a belt drive is try to use a motor with a shaft that extends though the pulley. My motor shafts only go about halfway into the pulleys and there is a much higher chance of the pulleys being pulled off the shaft by belt tension or vibrations.
  18. Beaver
  19. SteveT44
    I see a MACHO! brand rudder.
  20. Beaver
    I only run the best! :D
