Konig refit (open for opinions and suggestions)
Discussion in 'Warship Builds' started by Evan Fowler, Jun 1, 2021.
  1. Evan Fowler
    Evan Fowler Well-Known Member
    Muskegon, MI
    Finally had time to really get into the workings. Hope to be a quick refit. Started with reworking a 550 mount to house a 775 and added a hobbywing 880 esc. Looked good on the pond, to bad I didn't get any video 1622566155941408691500683862273.jpg
    Boatmeister likes this.
  2. Evan Fowler
    Muskegon, MI
    To repair the many drag prop holes i used a mix of fine sawdust and titebond III 16225667354581068762772656805652.jpg
    Nothing fancy wasnt 100% on drag prop rules so I kept them equal to the prop size at 1 1/4 inch. @Panzer suggested the shower pan liner for internal armor. Damage control is covered buy a B.C. large pump housing a stinger 550. Maybe in the future I will switch to brushless. Meh who knows. Used the deck as my mount for it 16225672687341043561376400518600.jpg the black lines are my thinking for the stern mounts also recommend by panzer. Eventually I'll have my print master 3D up some mounts
    Panzer and Boatmeister like this.
  3. Evan Fowler
    Muskegon, MI
    16229137536162127042077599718036.jpg still not 100% on gun mounts, need some time to feel them out before permanently mounting. Plus seems I lost a turret cover‍♂️. Meh problem for another day. 1622913907165178019891589787829.jpg and one more of the aft setup 16229140076863552902798180663475.jpg c turret looks good gotta figure out how I will mount up D maybe a small block to mount the barrels to. Any ideas would be greatly appreciated
    Panzer likes this.
  4. Kotori87
    Which direction does your ship naturally turn when you back up? You probably want your bow sidemount on that side, so when you step on the brakes your sidemount closes the range. It's easy to sail straight forward because your propwash goes straight over the rudder, but backing up is a whole different story. Once I swapped my sidemount to the other side I started having much more success with my little predread, precisely because a touch of astern throttle would swing the sidemount closer.
    If you know somebody with a 3d printer, you could ask for a 3d-printed Kort prop. We've been using them for years down in Georgia with very few issues. Also handy for replacing lost turret covers ;) Overall though I think your biggest improvement would be swapping to East Asia Squadron colors. White and Buff looks much nicer than Battleship Gray when you're kicking butt on the pond, and its easier to find all the holes you need to patch afterwards.
    Evan Fowler likes this.
  5. Bob
    A 1.25” prop is much too small. You should have at least 1.75” or 2”.
  6. Evan Fowler
    Muskegon, MI
    Thanks for the input!!! Hopefully I will some time next week to poke my 3D guy with a stick and throw a roll of filament at him. I am currently toying with duel sterns and dropping the port but I am the most indecisive . Thanks again for the recommendations. Also not sure on the color scheme thats just how she came into my possession
  7. Evan Fowler
    Muskegon, MI
    Finally getting back to it, made a few decisions on things but man its not like changing parts on a vehicle in anyway. 20210817_162621.jpg here is the 90% decided final layout!!!! Minus the rats nest of wiring. Needs some fine tuning but any progress is good
  8. Renodemona
    The bow sidemount I would move to the forward most turret so you expose as little hull to get it on target as possible. Not sure on the rule set you are using but those sidmeounts look like they have too much down angle (20 degress if I remember correctly) plus you don't want them too steep on the 'sweet spot' of hitting is very narrow. Other than that should be fine.
  9. Evan Fowler
    Muskegon, MI
    Will definitely look into rearranging hits to make that happen. Thanks
  10. Evan Fowler
    Muskegon, MI
    Seems the hard part is fitting the duals around the motor. Dang it
  11. Evan Fowler
    Muskegon, MI
    So after divination with the oujia board, trying to figure out how to fit guns around the 775. My only solution seems to be soldering the canons rather than using the compression fitting. Anybody have a German turret cover floating around? It may be some time yet before I get the pieces from b.c. on the plus side I did atleast bring my bad headway cell back to life, The charge on nimh did the trick. And thanks to @SnipeHunter for the firing boards I can get started on the kongo. Picture to come later. Thanks for everyone's input and suggestions to this point I appreciate it
  12. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
    I could CAD some up and print them for you if you need them.
  13. Evan Fowler
    Muskegon, MI
    Yeah not personally, its on the Christmas wish list
  14. Evan Fowler
    Muskegon, MI
    Wait I think I totally misunderstood what you said. How much we talking? I would gteatly appreciate it if its not a problem
  15. darkapollo
    Carlisle PA
    I edited my post after I saw you had said you didnt have a printer yourself.
    My printer is occupied for the next 2 days so itll be a bit before I can print them.
    Can you send me the dimensions of the barbettes (OD and ID) and some clearance info for the guns? I cannot 100% guarantee they will fit, but I will give it a good shot. I’m not one to charge for stuff. It is hard enough to source parts in this hobby.
  16. Evan Fowler
    Muskegon, MI
    That would be awesome. I will get them shortly. Thank you
    darkapollo likes this.
  17. Evan Fowler
    Muskegon, MI
    So not looking for fancy so much as effective. I have 2 inch pvc barrette. The covers I have are actually smaller than that currently, was also half the reason I ordered the deck kit from b.c. in hopes there kit had bigger. Any who my current turrets measure out 2 1/16 wide ( 2 inch pvc is 2 3/8") by 2 3/4" long. Just what it came with. No rush wont need it till Hagerstown ‍♂️. Need to get to work on the kongo compliments of @Nomercy. Thanks again 20210819_185252.jpg
  18. Evan Fowler
    Muskegon, MI
    20210828_163443.jpg huge thanks to @Panzer for building what I could not wrap my head around. First step to finishing the kongo 20210828_163648.jpg
    bsgkid117 likes this.
  19. Beaver
  20. Evan Fowler
    Muskegon, MI
    All the praise should be directed at craig. He did awsome. Hope to get it on the water next weekend
