Led lights for night battle
Discussion in 'Research and Development' started by ZARUBA1987, Jul 1, 2021.
  1. ZARUBA1987
    ZARUBA1987 Well-Known Member
    Tarkington Tx
    Looking for recommendations for led lights. National is fast approaching like to get the Doria rig for lights ASAP. If anyone has Recommendation I would appreciate it
    thanks
    SunkAgain likes this.
  2. Iunnrais
    Iunnrais Active Member
    Texas
    Here are my options: Simple LED harness that I can just plug into the ship on a spare firing circuit and my backup of tiny glowsticks (Walmart in the fishing section). The LEDs are simple white LEDs (
    View: https://www.amazon.com/Pieces-Clear-Light-Emitting-Diodes/dp/B07T5K4M8B/ref=sr_1_4?dchild=1&keywords=white+LED&qid=1625157620&sr=8-4
    for example) That I sleeved in a bit of brass tube to help keep the light going one direction. There's a bit of liquid electrical tape on the back as well to both coat the back of the LED and hold the tube in place. I made them up for the 2010 Nats and they've served me well. I did swap the connector this year and add a little more cable length. Generally just zip tie or tape them to a bit of super structure and then snake the cable down through a barbette to the electronics.
    edit: no idea why there's such a big block of white space in the text *shrug*
    jadfer likes this.
  3. Iunnrais
    Texas
  4. ZARUBA1987
    Tarkington Tx
  5. Iunnrais
    Texas
    Main purpose is to not lose track of your ship in the dark not to illuminate the shoreline. You don't want anything too bright as it will mess with your night vision and cause a 'bit of discord' lakeside.
  6. Beaver
    @Kevin P. gave me two of these last year. I wired them in series because my boat is 24v but all you need is a spare gun board and a 12v connection.
    https://www.ebay.com/itm/133399111552
    edit: forgot to mention they have the resistor already wired in which makes them super easy to use.
  7. ZARUBA1987
    Tarkington Tx
    Nice I will check them out
  8. ZARUBA1987
    Tarkington Tx
  9. NASAAN101
    I tho about getting those to put in the fake guns, what do you think??
  10. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
    I know I havent battled yet.. but a night game gave me a fun little “why not” idea.
    Search lights with 3mm LEDs.
    Simple circuit that runs off my 6v RX battery pack.
    I made wire passages in the superstructure for them and also hollowed out the admirals bridge, printed an insert in clear, and will use red LEDs in there. Also did the red and green nav lights.
    just for fun.
    572E738B-E7DC-45CC-821D-7EAC8D8FE92C.jpeg EF21B626-BDBD-4F66-8C83-2393AE568159.jpeg
