Lexington Class CCG
Discussion in 'Warship Builds' started by Ace_Austin, Dec 7, 2013.
  1. Ace_Austin
    Ace_Austin Active Member
    Work for the day added aft. Beav, if you really fall for the look... I hear her sister Sara is available. Just sayin.
  2. Beaver
    Really, really cool!!! Thumbs up, +2!!!! Can ask you a favor, could I have a "front on" photo showing the hull and SS, plus the same for the stern? Nothing wrong, just would like to see it.:)
    I've been considering a Lex or Sara for a convoy ship....
    Beaver
  3. Ace_Austin
    I will get those knocked out tonight..... ATG came by and said they couldn't certify the flight deck since it looked like ships company had drew the flight deck markings on with crayons.... Soon as they get those squared away I'll have some beauty shots up along with some from inside the hull.
    Definitely looking awesome. You're gonna make me go modern on a ship, I can feel it.
  5. Ace_Austin
    Tug you may not go full Monty like me, but maybe a FRAM Gearing, CA to CG conversion Baltimore, or a 1980's Iowa? Got bored waiting for paint to dry so i took a few topless shots...... of the boat.
    As the frame sits now she is about 9lbs. Three large tubes of concrete leveler and some balsa framework yielded a nice midships water channel. If I need to hard mount something I will just gouge a hole in the leveler, insert a mounting bracket and add more leveler to get everything back to perdy. The mounting brackets for the 550's on all four shafts were done that way.
  6. Ace_Austin
    Sorry for the low res on them. I am using just a cell phone. Fore and aft shots Beav, if you want any others just let me know. Next up I am going to start working down to the O2 and O1 levels... I have a little bit more freedom where I want to put things like CONREP rigs and 25mm mountings. I also need to find 1/144th 5" mounts.(The modern 76 cal vice the 38's) I figure those are close enough to 6" they will accept a slightly larger barrel.
    Hah, I already got plans for Wisconsin 1980 :)
  8. Ace_Austin
    I am debating going back and installing bilge keels. Quick slice into the fiberglass and then a little resin to seal it back up seems.... pretty straight forward. Same way I plan on installing the strut pylons I got from Strike.
  9. Beaver
    Thanks for the photos, looks great! :) For those 5" mount you were talking about, is this
    it?
    Beaver
  10. Tugboat
    That's a 3" gun, though :(
  11. Ace_Austin
    Huh? Who? What? Any links I do not see right now.
  12. KeriMorgret
    Seattle, Washington
    Ian, the hyperlinks aren't easily visible in this forum. It's actually the slightly darker "this" at the end of Beaver's post.
  13. Ace_Austin
    Ahhh I see it now. The Otos are the babys we stick on the Figs. I'm thinking of the 5"/62 Mk 45 the newer DDGs roll with.
  14. Hovey
    Hovey Admiral (Supporter)
    Washington
    I have to admit that I wasnt too fond of your hybrid idea at first. But you ave a done a really nice job of it. It looks great. Keep up the good work.
  15. Tugboat
    What about the MCLGS 8" turret? That would've been a good fit.
    Look HERE!
  16. Ace_Austin
    I saw that in my travels on Wiki. Right idea, I just can't find a economical casting for the dang things! A boss gun to give a DD
  17. Tugboat
    Can you make one and then cast copies? It's not too bad to do
  18. Ace_Austin
    A little JB Weld, a Dremel and BAM! She's got her wheels on now.
  19. Ace_Austin
    So by the way I read most BG rules, I sheet the entire hull with the balsa that matches the thickness of the main belt on a boat... As Lex has a belt of 7" listed I will be rolling with 3/32". Now the question is do you find it easier to sheet then apply the silkspan inside first or after the sheet is mounted to the hull? ( Now I just need to see if the local guy HAS any silkspan.)
  20. DarrenScott
    I sheet first, then apply silkspan outside.....
    Others apply silkspan to the balsa and then glue it to the hull silkspan side in.
    I'm still not convinced about that, as the balsa is then only held by the bond between it and the silkspan...
