Liberty ship build
Discussion in 'Warship Builds' started by wfirebaugh, Oct 14, 2019.
  1. NickMyers
    Make sure that you have a resin that won't eat your ship's frame.
  2. wfirebaugh
    wfirebaugh Well-Known Member
    El Paso Texas, USA
    I will have to have a test trial then. Mix up a batch and put it on a piece of scrap plastic. There are ways around it, thank you for the thought it would not have crossed my mind.
  3. jstod
    Also please let Denver to let us know how the frame holds up to combat. Very interested to see if it can survive
  4. wfirebaugh
    El Paso Texas, USA
    I was planning on buying a BB gun to test with but haven't got one yet, real life stuff, roommate ran out on us and disappeared with our deposit 750.00 worth and hadent been paying his house payment for the last four months. So wife and I had to move back to her mother's house... So we are a bit in the hole at the moment. When I start to fire test I will record it and post up.
  5. Selley
    Selley Active Member
    Butler, W.A
    picture two: looks like the ship has a lantern as a funel
  6. Nibbles1
    Nibbles1 Well-Known Member
    Orinda, CA
    Hahahaha. It sure looks like it! that would be an interesting funnel concept
    Selley likes this.
  7. wfirebaugh
    El Paso Texas, USA
    The funnel is 60-w paper with clear tape wrapped around the outside, I put it there temporarily. I have a wolf brand tin can here in front of me I am going to make the funnel and the rudder out of.
  8. Nibbles1
    Orinda, CA
    I think he means the lamp... if that is a lamp. It is in the second picture
  9. wfirebaugh
    El Paso Texas, USA
    No that is a lasko tower fan sitting on the floor.
  10. wfirebaugh
    El Paso Texas, USA
    I finished cutting out the frame pices and got it glued together, I the cut out template for the deck, next buy the material for that part, and buy foam to make the bottom of the ship.
  11. Julian Barbera
    Julian Barbera Active Member
    SF Bay
  12. Selley
    Butler, W.A
    I can see her shape of a liberty ship now
    wfirebaugh likes this.
  13. wfirebaugh
    El Paso Texas, USA
    Thank you Julian B. For the encouragement. :)
    When I go to fiberglass the bottom of the ship I am planning on Elmer's glueing on the pink foam so it can easily be removed. Sand to shape fill in the cracks and pits with some plaster, cover with some aluminum foil then fiberglass, remove everything then drop in the bath tub to remove everything that is supposed to come off, then glue on the skin of the bottom of the ship. Well that's the plan let me know if anyone has any ideas for improvement.
  14. wfirebaugh
    El Paso Texas, USA
    I did this work over the holiday weekend but was busey with life and didnt got to take pictures.
    I had finished the cargo openings and the mast housings. I took the deck template and cut it out in metal flashing, I had to cut it in half becous it had a really bad bulge in the middle to fix the issue.
  15. Julian Barbera
    SF Bay
    Good job on the deck!
  16. wfirebaugh
    El Paso Texas, USA
    Thank you Julian, I orderd N45 neodymium magnets to hold the deck and house down.
  17. Julian Barbera
    SF Bay
    Do these ships get pumps?
  18. wfirebaugh
    El Paso Texas, USA
    By the rules, I don't think so. From what I remember reading really only warships do get pumps.
  19. wfirebaugh
    El Paso Texas, USA
    I posted a answer earlier, but... There wear commerce rading liberty ships. That looked like helpless liberty ships but when a axis ship pulled up next to them to raid for supplies, pop out came the Xtra men with guns and went to man the fore and aft 3/6 inch deck guns, So in that case possibly yes. But they wear 10 knots fast like the standard ships so would it really be a good idea? I really can't say. But if you go by the rules the weapons are there so it is possible I guess.
    Selley likes this.
  20. wfirebaugh
    El Paso Texas, USA
    I have been busy with my wife and familie and school, here is where I am at rite now.
    Mr. Frodo was inspecting things and wanting to go inside.
    Some pices are still falling off so I had just reglued them back on, so I stopped to let the glue dry.
