Links for gears?
Discussion in 'Propulsion' started by McSpuds, Apr 7, 2015.
  1. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Does anybody have any good links to gears?
    I am having trouble finding 4mm bore 48 pitch gears....
    I might have to switch to 32 pitch.
    Any links would be helpful, thanks.
  2. absolutek
  3. rcengr
    Servo City has a pretty decent selection of gears: Gears I didn't see any 4mm press fit gears, but if you are pressing them on a shaft, 5/32 ID should work since it is just a hair smaller (0.001") than 4mm. They do have 4mm hubs which you can fit to a hub mount gear.
  4. GregMcFadden
    Hobbyking. and BTW, some of the 4mm bullet connectors happen to have a 5mm OD....
  5. GregMcFadden
    For reference. HK part numbers AM1003A/67 4mm ID 5mm OD bullet connectors (now used as shims)
  6. jadfer
    I use the hub mounted gears from Servo City. You can get a 4mm hub and then mount a 48 pitch spur gear to it.
    48 Pitch Nylon Gears (.200" Face)
    48 Pitch Acetal Hub Gears (1/8" Face)
    0.770" Set Screw Hubs
    I like the Delrin and have never lost a tooth or gear since I started using them. I use 32P .. every since I had a tiny bb sized piece of balsa get caught in the 48p gears and lock the entire transmission.. it resulted in this:
    (being a rookie was tough!!).
    I switched to 32P and never had an issue again... I even chewed through my 1/16 gun hose and didn't even know it.
