Littorio & Mackensen Kit run
Discussion in 'Buy, Sell and Trade' started by GregMcFadden, Feb 16, 2013.
  1. GregMcFadden
    Alright we are up to 4. that means that I will order 5 to get the price break. I plan to call and order friday so if there is any more littorio interest, let me know asap.
  2. Panzer
    Hell, MI
    I would love a Littorio or Mack whenever u run another set.
  3. GregMcFadden
    It is getting closer. I have a few parts left on the mack. now if I can get more than 15 minutes a shot...
  4. MasterClay
    MasterClay Active Member
    morris, illinois
    Looking forward to the next kit runs
  5. jstod
    Same here! :)
  6. radollar2000
    radollar2000 Active Member
    I'd be up for one of the Mack kits as well. That is a sweet looking ship! And then there is greg's skill on top. It's just going to be wicked! Okay now that my internal little boy has had his say. :)
  7. wrenow
    wrenow RIP
    Have you considered a DKM Kormoran kit? Relatively straightforward hull design, nice sized cargo ship and, under big Gun rules, not terribly bad as a commerce raider (not sure how those firt in under IRCWCC, MWC or Treaty).
    In Big Gun, it would be a good beginner ship that you could start out unarmed, and then add "oomph" in several ways as you gain experience.
    Cheers,
  8. GregMcFadden
    that is a good idea. I may have to do that this winter
    Any chance you'll have a file of the turret that I could borrow when the RepRap is set up?
  10. GregMcFadden
    certainly. I can export whatever you need. which ship, L or M or both?>
  11. jstod
    once you have gotten to the SS for the L would it be possible to get the CAD file? I new club member has his own laser cutter.
  12. Tugboat
    I can do turrets for both, those are easy. Also able to do smokestacks, etc. L's SS might need to be done in a few parts (8"x8"x5" print volume) but is easily within the realm of possibility, and the CAD file wouldn't need to be redone to yield patterns for pieces of wood; the Slic3r program takes the file and calculates the printhead path with a user-determined wall thickness and fill% for the inside of the box (so to speak)... once you feed it to the printer, you go eat dinner and check in on it once in a while. Superstructures are no problem in Sketchup, but I haven't worked up the nerve to try a rounded turret :)
  13. GregMcFadden
    if you can check the filetype I can send you a turret to try tonight
  14. Tugboat
    Printer not set up yet, but I can run it through the slicing software and see what it looks like. STL files are preferred, although if it's a format that I can get into Sketchup, I have a pluging that lets Sketchup convert it to .stl format.
  15. Tugboat
    Printer not set up yet, but I can run it through the slicing software and see what it looks like. STL files are preferred, although if it's a format that I can get into Sketchup, I have a plugin that lets Sketchup convert it to .stl format.
  16. GregMcFadden
    Alright folks... the mackensen design is done. drawing generation is underway. I am about a week out from having it in a quotable format. So consider this the call for interest. if you are interested in a mackensen, let me know via PM so I can get a list going and quote in the right quantities. same goes for a littorio, as I can have them all shipped to me in the same box.
    standard note applies to the mack that goes with the L kit... there may be minor bugs in the design. the L kit is fully documented in teh build thread as far as what one will receive. the M will include the bulk of the superstructure (see mackensen begins thread for pictures)
  17. MasterClay
    morris, illinois
  18. MasterClay
    morris, illinois
    Is there a future plan to do laser cut Littoro superstructure like you did for the Mackensen?
  19. GregMcFadden
    at some point yes, however if tug is successful at the rapid proto'd one at a reasonable cost that might change
  20. Panzer
    Hell, MI
    Pm sent
