Littorio
Discussion in 'Warship Builds' started by GregMcFadden, Jan 15, 2012.
  1. jstod
    You could always create a big gun presence there..... just saying haha
  2. GregMcFadden
    that may happen... stephen needs test beds anyways ;)
  3. jstod
    oooo smart move moving there. Now you can test new prototypes and get some ....ehem free samples...
  4. GregMcFadden
    I'm not after free... I am after fully functioning, and a good second engineer to look over my breech prototypes
  5. rbe
    rbe New Member
    A question about the sheeting. Did you bring the balsa and aramid on the bottom up to the bottom stringer so there's an overlap between the bottom sheeting and the side sheeting? I couldn't quite make it out from the pics posted.
  6. GregMcFadden
    There is a designed in recess for the replaceable side sheeting. I designed the recess at exactly 0.125 inches. No overlap
  7. rbe
    rbe New Member
    So the 1/32" balsa on the bottom doesn't go higher up the side than the recess?
  8. GregMcFadden
    No. there is no 1/32" on the sides of the bottom. that region was balsa blocked in between ribs. the only thing outboard of the ribs at the step is the aramid cloth I used.
  9. rbe
    rbe New Member
    Oh, I see. Very good idea. Thanks.
  10. Tugboat
    I did as Greg did, but with fiberglass cloth.
  11. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Greg,
    I just got stsrted on the ship since my Mutsu is 98% finished.
    I have a question...how do you suggest converting this hull to a fastgun ship? This hull has that .125 recess at the bottom to allow the thicker biggun balsa to lay down with no seam showing In fasgun we only have the 1/32" balsa......the recess thickness is way too much for fastgun and will leave a very ugly seam.... I am killing my brain trying to fix this...
  12. Tugboat
    I just sanded it off. Not that big a deal even for the anoraks out there.
  13. GregMcFadden
    Here was my plan (or plans)
    1. Temporary fast gun conversion
      1. Use 1/8" X 3/8" balsa strips to build up the ribs (will end up about 1/32 below flush with outside of glass layer if you build how I did)
    2. Semi-permanent fast gun conversion
      1. Use 1/8X3/8 basswood strips... added benefit it armors the structural ribs with a sealing layer so when a round breaks teh sealing, water only infiltrates the cap
    3. Permanent
      1. Tugs approach
  14. NickMyers
    I was intending to go with Greg's #2 option.
  15. rbe
    rbe New Member
    I haven't studied the guns yet, but what happened vis-a-vis big gun? Have there ever been venders who sold them? Did a vender go under? Is there equipment needed to construct them that is difficult to use or prohibitively expensive, or are the materials exotic?
  16. GregMcFadden
    It will be a while for updates until I have a shop again.
