Littorio
Discussion in 'Warship Builds' started by GregMcFadden, Jan 15, 2012.
  1. GregMcFadden
    Pardon the rather poor cell phone camera picture. the rapid prototyped tertiary came out quite good.... surface feels a bit like bonded confectioners sugar, so it needs just a little bit of smoothing but once filled with epoxy and detailed it should work well for mold making
  2. rcengr
    Very nice detail. What prototyping service did you use and what material is it made out of?
  3. GregMcFadden
    shapeways made it and it is their fine durable plastic. they have a superfine and smooth but it quintuples the cost because the material cost about doubles and the increase in required wall thickness further adds
  4. rcengr
    That's good to know. I was going to try the strong and flexable material first, but it sounds like it will have a really rough surface if the fine detail plastic needs smoothing.
  5. GregMcFadden
    my bad, I was using ponoko nomenclature. that is the strong and flexible. I would not pay for the finer graned stuff
  6. jstod
    Hey Greg any updates on your build? Also what size props are you planing on using?
  7. GregMcFadden
    40mm and smaller on the inner, 33mm and smaller on the outer. those are maxes and are very close to the hull. deviate much from the as modeled hull form and thsoe props will have to be set back a tiny bit to fit.
    the sizes were based on big gun scale prop rules.
  8. jstod
    That works perfectly for me. Thanks!
    I'm running a set of 2" props turned down a bit on the center positions. They still project below the bottom, but that's okay :)
  10. Panzer
    Hell, MI
    Throwing in my 2 Cents, But JUST AMAZING! Bee-utiful work!
  11. GregMcFadden
    Note thie white in the shaft holes. that is wax. the trick there is to apply packing tape over the holes, cut out the openings, fill with hot wax from wife's favorite candle... return candle to home, make sure wife does not catch you. shape with X-acto knife. scented candles work best as their wax is softer and never really goes hard.
    remove packing tape, glass over shafts (this is my final glass coat on main hull, got the aft 2/3 bow 1/3 still tbd. I did aft first so I can focus on finishing up propulsion and steering. Rudders are getting done but I will take pictures when complete. That being said, I know I said I would skip the kevlar next time but I am rethinking it. it may cut about as well as a high nickel alloy with a dull tool but it does result in thin, stiff, tough surfaces.
    and for those that missed the last kit run, this is what you missed
  12. GregMcFadden
    Prop shafts are in and clamped. they will have to come back out to put some rubber between clamp and shaft as well as to install mounting clamps for motor mounts, but they fit well now and come in and out easily.
  13. MasterClay
    MasterClay Active Member
    morris, illinois
    Dang I missed out when you did the run on this kit, wish I would have seen it earlier
    Jason
  14. GregMcFadden
    Shoot me a PM off line. Kits can be run again, however it usually kicks the cost up a bit to run just one. I am planning on running mackensen kits within the next two months, however, and I could add a few L's to that run. (mack has about 10 hours tops of cad work left before it is quote ready)
  15. jstod
    Whats your plan for your SS?
    (cant wait for the mack)
  16. MasterClay
    morris, illinois
    Great sounds good,a Mackensen would be a good sight too I'll have to keep a eye out for those as well
  17. GregMcFadden
    Get the mack done then work the super as I am getting my L on the water (too many projects). I have the secondary turret master ready to polish up and mold, same with tertiary. I need to think through the super a bit as there are a lot of annoying curves
  18. jstod
    Are you planning on having it laser cut as well or just build it out of foam?
  19. GregMcFadden
    Laser cut / some molded parts time depending. secondary and teritary lend themselves to rapid proto/mold
  20. jstod
    wouldnt the risk of the SS getting shot up make the cost to benifit ratio tip to it being very expensive over time?
