Lj's USS Texas(BB-35) SJS 3D Print complete Kit build
Discussion in 'Warship Builds' started by LjWolf303, Feb 14, 2025.
  1. LjWolf303
    LjWolf303 Active Member
    Payson, UT
    FIRST OFFICIAL BUILD POST.
    Update
    I just finished the body prep work to accept jb welding and feel more kid friendly on fingers. A couple of minor/ major parts came DOA. Will already shipped replacements. (Both Props and a lost tooth/peg on one of the gear box covers) no big deal. Nothing a 3d printer can’t fix. Unless you don’t use ABS.
    Tomorrow
    I will take pictures of it on my bro- in law work bench. This where it will live till it is completely finished being built.
    My step one
    I pre bent the rudder shaft onto the rudder so I will not be able to remove it easily. I got ahead of myself. Haha oops
    Superstructure
    I will buy brass tubing for the towers 6/32? I believe? Tubing for my pump exhaust (Will I don’t know the size I will need) and fake barrels which are 1/4 brass tubing.
    Hull
    I will put all screws on losely on the hull. fill gaps with jb weld. Tighten screws and zip tie. Let the hull dry overnight.
    Start working on the Superstructure as the hull dries. Still figuring out how long and how much brass tubing I will need for the structures.
    tgalx3 and bsgkid117 like this.
  2. bsgkid117
    The pump outlet through the hull should be 9/16 OD .014 Wall brass to accept a 1/2" OD vinyl tube. The brass tube that goes into the pump body itself is 13/32 OD .014 wall brass, to be a tight fit inside of the 1/2" vinyl tube.
    The superstructure rods/tubes/etc are all 1/4 or 3/16. If holes seem a little big, it's for clearance so the holes aren't too tight for easy assembly.
    Edit: using the browser 3d view I sent you, you can hide parts to see inside and there is a measure option for you to check measurements on things
    LjWolf303 likes this.
  3. LjWolf303
    Payson, UT
    Todays accomplishment. We didn't quite know where to start, so we just went stern to bow. Are reasoning was we wanted to drill out the prop shafts and not have to work around the entire hull. We wanted to work with gravity and not fight with it.
  4. LjWolf303
    Payson, UT
    First image is all acetone and sanded, ready to be JB Welded. I used JB Weld plastic bonder.
    Second image done JB Welding it. So we started at 7:30 and finished at 9:00 and it was still tacky. We made sure it was equal parts as directed. Because we live in Utah and it doesn't know if its spring or winter so the environment is colder for now.
    Third image is let not waste not. Used some JB Weld on the rudder shaft onto the rudder.
    That's all for today. We are hoping for tomorrow we will accomplish:
    1st Find brass tubing. 3/16, 1/4, 9/16, & 13/32 (I don't want to order online)
    2nd Drill out 3/8 holes.
    3rd JB Weld the entire hull. (Now that we kind'a have a plan of attack.)
    bsgkid117 likes this.
  5. LjWolf303
    Payson, UT
    Todays accomplishments
    Hull
    We drilled out the prop shafts and secured them before JB welding the entire hull together. The shafts, we split the difference between inboard from the outboard. Errored on about a 1/4”on the inboard. I ordered brass tubing. 3/16, 1/4, 9/16, & 13/32 (From Amazon)
    We magnetized the hull because why not they aren’t in the way and one less thing to lose. I superglued them but I am thinking about going over all of them with epoxy. What do you guys think?
    Superstructure
    I superglued the first layer to the second layer and bolted the first layers together.
    On one of the towers I completely assembled it and superglued it.
    We looked at the cranes and weren’t really sure how to assemble them after reading the instructions. Wasn’t really clear because of no pictures.
    Barbets and Turrets
    We Didn’t know if we should have glued the barbets to the deck or not so we didn’t and pressed fit them. Then superglued the turrets to the barbets.
    Tomorrow
    We are taking a break from the hull. So I plan on getting the brass in and finish the superstructure.
    Boatmeister likes this.
  6. bsgkid117
    The turrets are meant to magnet to the barbettes so you can access the cannons to load/adjust the tweak on the O rings.
  7. tgalx3
    tgalx3 Admiral (Supporter)
    Snohomish, WA
    Looking really good!
  8. LjWolf303
    Payson, UT
    So what I mean is deck to barbet we didn’t glue it together it’s pressed fit. We magnetized barbet to turrets.
  9. LjWolf303
    Payson, UT
    Thank you
  10. LjWolf303
    Payson, UT
    This is what I was talking about. I made the base removable from the deck. If that’s a bad thing, I won’t continue using that method.
  11. LjWolf303
    Payson, UT
    Today’s update.
    I completed 95% of the superstructure with the brass I received. I have one more 1/4” piece to fill in on the little tower structure. The big structure is completely done. Ready for primer. I also laced the decking with epoxy to help keep the magnets in place more permanently.
    So, the big superstructure is 1/4”. Get 3 x K&S 12”packs.
    I made do with what I had but for future reference.
    The small superstructure is 3/16” and a single 1/4” piece.
    I used a small piece of 13/32 for the beige pump.
    I’m not sure what the cranes are?
    I have 13/32 and 9/16, neither work.
    Tomorrow
    My plan is:
    First, get the hull ready for primer.
    Second, attach the stringers.
    Third, epoxy the magnets on the hull.
    I’m not sure how to attach the superstructure to the deck and make a retrieval line?
  12. bsgkid117
    There are a lot of methods to attach the SS to the deck, it depends on how you want it to work. You can just glue it down, call it a day. You could maybe glue in a piece of something to add some magnets to the main SS body, have the whole main forward/mid SS magnet down to the deck. Then fill the SS with pour foam and anchor to the hull (not the deck) with a recovery line. That would make a whole SS float.
    With my kits I try to help people with a lot of the "Clueless new guy" decisions/mistakes, but I also purposefully try not to take away all of the "figure it out" effort that is required...a lot of captains in the hobby just flat out do not agree on certain building techniques. Like, a whole SS float vs maybe just using a turret as a float vs not having a float at all for those that like to live dangerously. You kinda have to figure that out on your own as the kit doesn't have a clear answer one way or another for you.
    The kits do make sure your prop shafts are in the right spot, props aimed at rudder, windows and casemates are cut out correct, etc.
    The crane uses a 3/8" dowel/tube/rod/etc for its primary base. You would want to look at reference photos or your plans to figure out exactly how tall you want it.
  13. LjWolf303
    Payson, UT
    Today’s report
    We sanded the entire body and it’s prepped for primer. I added the missing 1/4” tubing in the small tower. Both towers are completed. All we need to do is add the stringers.
    I just need to get: more JB Weld, paint, and contact cement.
    I’m near complete with what I have been given.
    Boatmeister and bsgkid117 like this.
  14. LjWolf303
    Payson, UT
    Today
    I accomplished finishing one side of stringers.
    Tomorrow
    I plan on getting the other side of stringers and the bilge pump exhaust done.
  15. tgalx3
    Snohomish, WA
    Looking good. Keep it up!
    It's especially refreshing to see a new captain so gung ho and making so much progress so fast! Love to see it!
  16. LjWolf303
    Payson, UT
    Thank you! tgalx3 & bsgkid117.
  17. LjWolf303
    Payson, UT
    Any suggestions on how to cut that 9/16 brass pipe at that angle?
  18. LjWolf303
    Payson, UT
    Yesterday’s update
    Hull
    I completed the other side of stringers. Also, we completed the cranes. We figured out how to cut the bilge pump exhaust out. It turned out very nice. Ended up using a grinder.
    Superstructure/ barbets/ turrets
    I threw on some primer and paint and I’m super excited!!!
    Tomorrow
    I would like to get more painting details into the superstructure, barbets, and turrets.
    Boatmeister, JustinScott and Beaver like this.
  19. LjWolf303
    Payson, UT
    Today’s report
    I completed painting my superstructure and deck. They look beautiful.
  20. LjWolf303
    Payson, UT
    We used an angle grinder. Worked very well. Set it up on a vice grip and table. We shoved a small piece of rebar into it to keep its shape on the vice.
