Lj's USS Texas(BB-35) SJS 3D Print complete Kit build
Discussion in 'Warship Builds' started by LjWolf303, Feb 14, 2025.
  1. LjWolf303
    LjWolf303 Active Member
    Payson, UT
    Yes I will
  2. LjWolf303
    Payson, UT
    Pneumatics and electrical.
    Obviously 2 propulsion motors and the servo for rudder and that assembly.
  3. Nomercy
    Nomercy Well-Known Member
    Maryland
    Is that a fly fishing reel?
  4. LjWolf303
    Payson, UT
    Indeed it is.
  5. LjWolf303
    Payson, UT
    Completely light weight. And fits nicely in the compartment.
  6. bsgkid117
    What are you using to weigh it? The design target weight for the kit was 27.4lb, so you're not far off but based on your pictures of components I'm surprised you're saying you're so heavy.
    I use a postal scale which is typically pretty accurate.
  7. LjWolf303
    Payson, UT
    I recently got into field charging cases for charging batteries at the lake and not having to bring so many. Depending on how many amps you have the charger set to charge your batteries, is how fast they will charge.
  8. LjWolf303
    Payson, UT
    The station.
  9. LjWolf303
    Payson, UT
    That’s the thing, I’m not intentionally weighing it down. I’m using some 16 and 22 gauge metal components but I’m starting to switch out to balsa. Like for the rear electrical components, I’m using a metal tray to hold the ESC’s.
  10. LjWolf303
    Payson, UT
    Update
    I still haven’t put the siding on and I’m still working out the kinks that keep popping up.
    - I get the pressure to about 100psi and lines start popping off. All lines are from clippers. Brass barbs are from Amazon. I can’t keep them tight enough for 150psi.
    - I have t gone back over all my fittings yet with gas tape.
    - weight is still high for my liking 25/32 unloaded
    Trying to keep it light as possible.
    - metal has been swapped out for balsa. Except for near the air tank.
    -rudder parameters is set to high need to reprogram that.
    - need to adjust my props because I get a gear grinding sound meaning I need to tighten the motors. Do a final check.
    - last minute small gun add ons.
    -final paint scheme
  11. mabgfounder
    mabgfounder Member
    Salem, Virginia
    Clippard makes little "hose clamps" to use with their hose barbs. It is basically a little brass sleeve that prevents the vinyl from expanding and popping off of the barb. They do a fantastic job increasing the reliability of hose barbs.
