Make Class 1 Great Again
Discussion in 'Warship Builds' started by Kevin P., Nov 10, 2017.
  1. djranier
    Looking good Kevin.
  2. Kevin P.
    Thanks Dave, I cranked out three hulls this weekend
    Here is hull 2 laid out
    Drying
    Used tape to mark the top, came out much better
    Hull 3
    Drying
    Marked windows on the hull I will build out
    What’s that sound, I think it’s the axis captains quivering in their boots
  3. Beaver
    Just got my hull from Kevin. It looks and feels awesome. Nice thickness and not too heavy. Can't wait to see two or three of these tearing up the ponds this spring. Axis hulls beware. ;)
  4. Kevin P.
    Cut out the hull yesterday
    Weighed out to 15 oz
    Focusing on other projects, might get the shafts in tomorrow
  5. pigeonfarmboy
    Champaign, IL
    Nope just the sound of your floorboards giving from all the crap you have in that room! ha!
  6. Kevin P.
    The floors are reinforced concrete so I think it can handle a few more boats haha
    Tested the weight of the main components, came out to 3lbs 9oz
    Moved on to shafts, used shafts that I removed from the Fiji with a slight modification
    Made a guide for the ends of the shafts
    Tacked the shafts in place
    Taped the underside
    Epoxied in
    Props on
    Side
    SteveT44 likes this.
  7. Beaver
    Looking good! What size props did you go with?
  8. Kevin P.
    I have 1” 4-blade props on there
  9. Kevin P.
    Update on progress. I got the rudder post in and made the subdeck. Subdeck is 1/8 ply, I’m planning on 1/16 basswood for the deck. Rudder post visible on the 2nd ship down
    Should have good coverage of props
    Weight test. About 3.5 lbs which is good, max is 5.5
    Co2 will go in the bow
    Started subdeck
    This step is always a pain
    Side
    I dremeled out the underside for magnets
    Clamped, didn’t come out great, but good enough. Just a class 1 boat haha
    Dry
    Excess to cut off. I use a layer of mat between the deck and hull to improve contact area
    Deck and motor/ pump mounts next
  10. Beaver
    Looking good dude! I'm gonna have to get moving on mine. :)
  11. Beaver
    What size ribs are using, Kevin? I notice you have 11. 3/16"?
  12. Kevin P.
    I reduced the bow and stern area to give me enough ribs, they are 1/4.
    Some updates. Worked on pump outlet tube like my other builds, this should prevent the pump stream from rolling the boat
    Bow deck will be permanent, 1/16” bass wood
    Motor and pump mounts
    Pump outlet tube
    Bow deck
    Fast forward to electronics, I’ll be using a control box that can be swapped between boats easily. The core is the BC multi cruiser board, that controls the pump and guns. This board is a big step forward for the hobby. It really is plug and play. Also in the box will be a hobby wing ESC and the cheap receiver from BC.
    Cut out the bottom for the ESC to get cooling
    Overhead
    This is about it for the boat, very clean setup, with the test switched for Fiji
    Here is the box. Whipped it up from 1/16” plywood, not pretty but it should work
    Overhead
    Motor mounts next day. 380’s are probably overkill, but I should have weight to spare
    Pump and motors
    Cut the pump outlet tube flush
    Cut out the decks, 1/16” bass wood
  13. Kevin P.
    More progress, small steps
    Worked on gun placement. Here is fwd upper barbette
    Extra piece of wood on underside to hold it
    Guns in place
    15 degree off
    Looking at internals, guns might get in the way of the CO2
    With other things inside
    Moving aft
    Checked the weight with everything, 4 lbs, still 1.5 til max. Center of gravity looks good too, balanced on a level
    Looking inside at arrangement, considering moving the CO2 to between the motors, gives more space up forward for control box, solenoids, LCF was still good
    Side view forward with more room now
    Put on deck magnets, thin version will be bumps on the deck
    Sealed up the deck rim with epoxy, layer of cloth over the deck for B.B. resistance
    Forward deck with a layer of cloth on top
  14. SteveT44
    Kevin, try to make those 1/2 unit cannons as gas efficient as possible. A 12g cap barely pushes 50 rounds through my Mog cannon so you may have issues with the dual setup. If you can up it to a 16g cap, you should be fine. Looks like we may have three or more CL's on the water this year. Should be interesting.
  15. Kevin P.
    Thanks for the heads up Steve, I have a 16g setup on the way :)
    I'm hoping to get some battles in with these little guys during 'social/repair hour' between the normal fleet battles
  16. Kevin P.
    Internal armor is in
    I’ve been dividing time between too many projects haha
    16g setup arrived as well, I will be working on mounts for the rudder servo, the CO2 cartridge, and the bow guns next. Little boats come together quickly
  17. Kevin P.
    Some work done on this project.
    Made the turret mold at the same time as agincourt. Decided to do a 2 part mold based on the tall vertical section, otherwise I probably wouldn’t be able to pull the part out
    Green film applied
    First half
    Wall removed
    Both sides done, drilled and taped holes for alignment
    Ready for molding
    Wait 8ish hours
    Moved on to gun mount. The idea is to support the guns but keep weight a little lower, came up with this plate
    Epoxied with deck
    Put in edges for the water channel, 1/4 square bass wood. Plan is to finish everything then see how much weight is left over, then fill the waterchannel as necessary with heavy things
    Testing gun fit. Made up copper mags as an option
    Also considering plastic mags. I assembled per Steve’s instructions. I might test it out, slightly worried about suffering a magazine ejection casualty
    Made superstructure at some point, test fit with turret
    Checked internal space and weight again
    Comes in at 4 lbs 9oz here, 5.6 max
    Check balance, looking good
    Also made a second control box, v2.0, slightly smaller to better fit
    Finishing up internal mounts, pump hold down
    Also CO2 holder. No room up front, so moved aft.
    Holder, hole is for pump outlet
    Kind of tight, should be fine
    Fore and aft holders
    Rudder servo mount
    Made rudder next.
    Glued together
    In place
    From aft
    Drying with cloth
    Mounts drying
    kgaigalas, SteveT44 and Beaver like this.
  18. Anvil_x
    weight distro was my one concern with those Avengers, since the whole mag is in the superstructure. I like your mount idea.
  19. Beaver
    With my latest gun design you can run the mag along the keel if you like. Keeps the weight low in the hull. Photos in my Tromp thread. :)
  20. Anvil_x
    Awesome. I'll check that guy out
