Make Class 1 Great Again
Discussion in 'Warship Builds' started by Kevin P., Nov 10, 2017.
  1. Kevin P.
    Knocked out a few remaining things
    Sunday was a lot of soldering, escs battery leads, pump relays for other boats
    Glued in the battery holder, also two bolts to hold trim weights (washers)
    Epoxied the test switch guard and turret
    I used magnets for turret holding
    I fixed the solenoid issue and put the test switches in
    Battery in place
    Painted the bottom. Hopefully this doesn’t become this ships preferred battle position
    Weight was good, right on max. A few shots all together
    Still need to test CO2 system and guns, and sea trails.
    rcaircraftnut, WillCover and Beaver like this.
  2. Beaver
    Wow, nicely done, Kevin! Now if I can touch half as good with mine, I'll be happy. :)
  3. Nate G
    Nate G Well-Known Member
    Bradford, PA
    Well done. I am a big fan of the plastic chain drive in small craft
  4. djranier
    The pump relays don't have fly-back diodes on them? Not that I can see them in the picture anyways. The band on the diode should face the + voltage. You relay needs it if your triggering it with a solid state device. Across the coil, your small wired connection. 1N4001 works fine.
  5. Kevin P.
    Thanks Dave, I typically put diodes on the ship side of the wiring vice component side
  6. djranier
    I had a feeling you did, but thought it be safer to verify.
  7. Kevin P.
    I should have known that this boat couldn’t perform at the level of a real Tromp without a decent spray tan
    Did we ever find out how Steve found these things? And Steve, do you recommend one thick coat or multiple thin layers?
    SteveT44 likes this.
  8. SteveT44
    A GoogleFu master does not easily reveal his secrets..... ;)
  9. WillCover
    WillCover -->> C T D <<--
    Harrison, Michigan
    is that the same as...Don't ask don't tell....Sir!:laugh:
  10. Beaver
    I thought only typist used that sunless tan stuff since they never do get out to battle in all the UV light and radiation with us. ;)
  11. modelshipsahoy
    modelshipsahoy Vendor
    Michigan
    I’m only allowed to work on warships when I’m all caught up on other stuff or the Boss gets up-ity.
    But, I’ve been a good boy lately so I got to lump the Baltimore; John C Butler; Tromp plus Turrets for Tirpitz and Florida into a mold tooling session with the new 42” Gas Cat.
    buttsakauf likes this.
  12. Renodemona
    I would be interested in a Tromp hull once they go to production.
    modelshipsahoy likes this.
  13. modelshipsahoy
    Michigan
    Hopefully next week... God Willing and the Creek Don’t Rise... We have 2 sons with science fair projects hitting crunch time, so we have a wind tunnel muscling into some shop space. Plus our Daughter has Mock Trial Regional this weekend so we shall see.
  14. Jay Jennings
    Very nice Kevin! Colour me impressed! I have a question though, what class of ship is it? All those Allied boats look the same to me ;).
    Again, nice job.
  15. bsgkid117
    Jay Jennings and modelshipsahoy like this.
  16. Jay Jennings
  17. Jay Jennings
    And I now get the pun in the thread title...
    But, I see the Tromp is a class 1 with 1 1/2 combat units. But I see 2 1/2 units in the build, 2 guns and a pump. Did the build rules change or am I just missing something? Thanks,
  18. modelshipsahoy
    Michigan
    Rules now allow low class units to split cannon units to fill gun barrels. So you see 2 half cannons
    Jay Jennings likes this.
  19. Jay Jennings
    Ahhhhhh,
    I see said the blind man..
    Thanks,
  20. modelshipsahoy
    Michigan
    ... to his Deaf Wife as he picked up his hammer and saw. ;)
