Modelshipsahoy Prinz Eugen Details
Discussion in 'Vendor News' started by modelshipsahoy, Sep 1, 2018.
Do you believe in free market principles?
  1. Yes
  2. No
Results are only viewable after voting.
  1. modelshipsahoy
    modelshipsahoy Vendor
    Michigan
    It’s been a hard 15 years in mothballs for the PE superstructure mold. D48B5EA6-D3B0-4E02-940B-B2DB6757E170.jpeg
  2. modelshipsahoy
    Michigan
    Preparation is key 8232867E-1CFD-41A6-9270-4755ADECAF5A.jpeg Jamming the Grateful Dead...adding a touch of grey
    The mad scientist 0F2D3D7A-2AE3-4BEC-92E8-33A536D5239D.jpeg 018B0D68-B72E-411B-954F-5A7517B19956.jpeg
    We shall see how this works out in the morning...
    buttsakauf and Beaver like this.
  3. WillCover
    WillCover -->> C T D <<--
    Harrison, Michigan
    you ENJOYING those fumes?:laugh:
    modelshipsahoy likes this.
  4. modelshipsahoy
    Michigan
    Yes. Love em! ...but that entire bench is a down draft spray booth. When I crank it on, I have to tether myself so the breeze doesn’t suck me in.
  5. modelshipsahoy
    Michigan
    No joy. 4 oz of materials... not enough. Foam has to fill the entire mold and go into compression or it shrinks on curing. Upping to 6oz C16C8F32-CD8A-47C0-BAFF-5729F49448DD.jpeg CA80AB95-01E2-49F1-B78E-6F2D8602FABC.jpeg
    Evan Fowler likes this.
  6. NickMyers
    Is that the PE post nuclear blast testing?
    Panzer and WillCover like this.
  7. modelshipsahoy
    Michigan
    Great Idea Nick! Marketing is everything!
    WillCover and NickMyers like this.
  8. modelshipsahoy
    Michigan
    The real problem with this stuff is that it continues to contract if the core structures don’t develop density...
    Just in the two hours since it left the mold, it’s curled up like a potato chip.
    FYI will cover ...downdraft fan doubles as dust removal with the flop of a flap.
    WillCover likes this.
  9. GregMcFadden
    If you take a look back at some of the ~2006-2008 vintage threads on the my tirpitz build, you can see a bunch of parts built from the foamit stuff. I had very good results with the 25lb/cu ft stuff. It did not seem to be this sensitive to fill, as the only problem I had with low fill was a slight porosity in the surface. While I never went as far as to actually make the mods to the molds i intended to, it was sufficiently durrable at only 1/4" thickness that I had intended to basically make molds that held wall thicknesses to 1/4"-3/8" and use it. I actually used the scrapped parts as bouncing rifle targets before that was a big thing and they held up remarkably well even to that.
  10. modelshipsahoy
    Michigan
    This stuff must be closed molded. Once I get the proper amount measure for materials, parts come out rock hard and very light. This smokestack was made 15 years ago and still looks great. Mold gets clamped closed and the foam sets up too packed in to shrink FC8046EF-6CC5-4D4C-B68F-103FE22E9D26.jpeg
  11. modelshipsahoy
    Michigan
    Pulling the bases off the molds to build pressure lids. While a rack full of powerboats (and the PE) in gel cure. 7878F397-8633-4FCC-B104-9B74F6CE2C32.jpeg A5E70499-296C-4703-8260-FDDC96DFF81A.jpeg
  12. modelshipsahoy
    Michigan
    Evan Fowler and Xanthar like this.
  13. modelshipsahoy
    Michigan
    B3907B06-2B5B-4B31-BA0F-B5E37F6111DA.jpeg Had to post this for fun. A few days have passed... the shrinkage continues.
    Lou, WillCover, Beaver and 1 other person like this.
  14. modelshipsahoy
    Michigan
    All caught up on powerboats... time for some fun at attempt #2. With a good part from 15 years ago as inspiration. 289F915E-70F5-4829-8696-F99D51D38992.jpeg
  15. modelshipsahoy
    Michigan
    Fitting out the armor
  16. modelshipsahoy
    Michigan
    All vertical surfaces are armor as well as the thin deck areas... That outa fend off a shot or two
    buttsakauf likes this.
  17. modelshipsahoy
    Michigan
    Pre-heating the materials makes a big difference with this stuff. 71 degrees in the shop, so I’m kicking it up to 80
  18. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    I had no idea it was so sensitiveo_O
  19. modelshipsahoy
    Michigan
    Sweatin’ to the moldies
  20. modelshipsahoy
    Michigan
    I think I used enough this time!
