Montana class big gun project.
Discussion in 'Warship Builds' started by jstod, Oct 1, 2016.
  1. jstod
    Ok cool thanks for all the tips looks like I have a few options to choose from
  2. BigGunJeff
    BigGunJeff Well-Known Member
    not if you pre drill
    nmmichris likes this.
  3. jstod
    i will definitely consider doing that then. Have you seen any added benefits to the wood screw va glueing?
  4. jstod
    So I got some of the GOOP stuff. I did a little test with it last night. I took two scratch pieces of wood and put a little little on it to test the strength. This morning the bond was pretty strong. It says it takes 24 hrs to fully set so I'll look at it again tonight. If it holds like it is supposed to I'm probably going to go with that option
  5. jstod
    Got her all taped up to start attaching the subdeck with GOOP. The bow area will not allow to come in from the bottom so I have to figure out a best way to glue it down.
  6. thegeek
    E6000 is much thinner and will flow. You can get it at Michaels.
    Same as GOOP but thinner.
  7. kgaigalas
    kgaigalas Well-Known Member
    Grand Rapids, Michigan
    Your bow has a long solid section.
    How will you get BB's out
  8. kgaigalas
    I would like to see IRCCWC allow a Montana
    It adds diversity to the fleet and
    it is not too heavy for the people that want it.
  9. jstod
    I have a long magnetic rod used to grab bolts and what not in auto shops. Works great for the ball bearing. See attached
    That would be an interesting site indeed. I'd love to see her traveling around at fast gun speeds haha
  10. kgaigalas
    I use that for my BB's
    When I reinforce the ribs and attach armor and balsa you build a box to trap BB's
    I have seen Iowa's that you have to tear off the balsa to empty BB's out of the bow
    Seems like you have solved that problem.
  11. jstod
    I'm also considering cutting an opening in the fo'c'stle for a second float. Normally I wouldn't think a ship this size would ever sink but I have witnessed a mighty Iowa class sink bc of not plugging in the pump so things happen. I like two floats fore and aft. This lady has plenty of room.
  12. NickMyers
    sheesh, that thing is big, the Mack is no tiny ship
  13. NickMyers
    I'd like them to allow well-sourced hypotheticals too, like the Mackensen, which was started and the hull actually floated, but never finished.
    CURT likes this.
  14. thegeek
    That is what Treaty is for right?
  15. NickMyers
    only if you want all the other differences
  16. kgaigalas
    Do you think the IRCWCC would like a Montana.
    There is no big advantage over other ships and some people have built it.
    CURT likes this.
  17. Maxspin
    Maxspin -->> C T D <<--
    Yelm, Washington
    I think the AXIS would like a Montana. Not so sure that the ALLIED admiral would be happy to see one show up.........
  18. kgaigalas
    I agree, but is that the only reason to exclude them
  19. jstod
    No make is not tiny haha
    Update: subdeck glued in just need to finish up the bow area. I've also finished drawing the ribs on one side. Gonna have to double check my forward measurements. The line at the bow on the bottom is the estimated star of the bottom hard area. I measured 1" below the water line to get that line but it seems high. If it's correct then this beast has a lot of hard area. Considering the size I won't be surprised if it's correct. I've also drawn the lower edge of the stringer.
    CURT and NickMyers like this.
  20. Maxspin
    Yelm, Washington
    The Mackencen is another question. 24 second, dual rudder, haymaker, low profile........
